Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Had a problem with the brushroll now its burning up the flat belt
I have a Hoover Windtunnel self propelled bagless model # U6637960 I just replaced the drive belt and v belt and the brush roll is still not working. When I lower the handle the brush roll is supposed to go to the on position but it does not. found the problem that the vbelt was not around the idler drive deally but now the flat belt keeps burning up and halfway coming off if I put it in the upright position and the brushroll stops
  • 57 Answers
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Posted on Jan 06, 2009
The brushroll stops turning.
Hoover Windtunnel Self-Propelled Vacuum Belt ... - YouTube
? 2:54
www.youtube.com/watch?v=AJL9McF7MAU
May 22, 2012 - Uploaded by Crucial Vacuum Fits: Hoover U6423-900, U6425-900, U6425-920, U6429-900, U6430-900, ... U6616-900, U6617-900, U6625-900, U6626-900,U6630-900, ...
Aug 06, 2015 | Hoover U6630-900 WindTunnel Bagless...
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Burning up belts
does the brushroll rotate freely? most of the time the brushrolls lock up and the belt burns up
Dec 31, 2009 | Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
293 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
