Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer went off. Lost power and won't turn back on.
All of a sudden, my MP600 printer just went off and stopped working. I've checked the plugs to ensure it's plugged in, and all looks O.K. It is only a little over a year old. I press the "on" button, but nothing happens. What is wrong? Can you help me, please?
Thanks,
Donna
I had the same problem. The fault was in the print head. After removing the print head, I was able to get power to the printer. To test this, you need to open the top lid, lift the print head slightly with your fingers, pull it to the middle and remove it. Close the lid and turn power on.
Posted on May 17, 2012
    Sergeant:
    Novelist:
  • 183 Answers
Try "reinitializing" the device (printer):
  1. Shut down the computer system the printer is connected to.
  2. Unplug the printer power cord from both the printer and its power outlet.
  3. Wait at least 5-10 minutes, then re-plug both ends back in.
  4. Switch on the power button to the printer (if no indicator light is on).
  5. Restart (reboot) system.
Also, you can also rule out it being a failed power outlet by trying a different one to plug the printer into.
Good luck, and please post back to let me know how things work out, or if you have any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 22, 2008
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
"canon mp600..it's about 4 or 5 years old. It
The Power Supplies for the MP600 burn out over time. They are easy to buy and replace:
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Jul 13, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My display screen is no longer working. We had our MP600 printer/scanner turned off while we were out of town. When we got back, I turned it back on, but the display screen only has vertical black and...
Hi there
Can you try to unplug the power cable of the printer for 2-3 minutes and then plug it again firmly.
If not, try to replace the power cable if it solves your problem. If your printer is under warranty, let them repair your printer. Leaving them the head ache
Regards.
Feb 18, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600r won't turn on
Try to unplug the printer wait for 120 seconds and plug it back into the wall for power. Make sure that the power cord is plugged firmly on both ends, at times they become loose, very common. If this does not work please explain when was the last time it worked and anything else that could help to resolve the issue. Thanks
Sep 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600 stopped connecting to computer
try to transfer the usb cable to another USB port..or swap with the another working USB port..and restart your computer..
May 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
My printer will not turn on
Here are some things to try:
1. Different plug (outlet) just to make sure it isn't the plug causing an issue.
2. Unplug the power cable from the back of the printer itself if possible and plug it back in while holding down the power button.
3. Unplug the printer from the computer all together and see if it powers up.
4. If it's a separate power cord try to find one similar in nature to plug in and try out as it may be the cord.
Apr 29, 2009 | Epson Stylus C66 Photo InkJet Printer
Printer Canon MP600 turned Japanese!
There are language settings. Go to the main menu and rotate through to the pliers/screwdriver icon. (settings) Click the right button to select the icon with two sliding tabs. (device settings) Scroll down 4 selections to language selection. Select English.
Dec 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
646 people viewed this question
old marine
old marine
