Question about Compaq UPS R3000 (242705-001) UPS System
Compaq r3000 ups drops out while pluged in to a\c power
The ups will work fine indefinitely then for no apperent reason it will lose power on the output plugs and none of the LED's change, if you the cut the a\c power to the unit it will switch to backup and restore power. Then you can restore a/c power to it and it will run indefinitely again and repeat the cycle. The batteries are fresh and it only recently started doing this, it is as if there is some kind of circuit breaker,other than the ones on the back, inside the unit that is letting go prematurely. Only 1 LED is lit on the load bar so it should not be overloaded, I know for sure, from amp measurements, that it is only supplying 4 amps of power normally and 11.7 amps with everything possible on.
Thanks
Did you ever get a resolution to this issue? I have the exact same problem. Someone advised that I should ensure that the Sleep mode is disabled through the config but that is already the case. Do you by any chance have the UPS in a non-air conditioned room where it might be getting too hot? Secondly, do you have both the battery leads connected to the battery pack or just one of the pairs is connected?
Posted on Jun 05, 2009
Does the battery have to work for the lap top to work when pluged in on the Presario R3000?
Check your AC adapter if still work. Battery don't have to work when is on AC.
Dec 26, 2011 | Compaq Computers & Internet
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Power problem
All batteries lose their ability to store power after every recharge. I would say the problem is the battery so get a new battery soon but don't forget to charge the new battery. If the problem is still there after replacing the battery, then my next guess is the laptop.
Aug 02, 2008 | Compaq Presario R3000 Notebook
Laptop won't stay on
it might as well be a internal problem related to power or loose contacts with RAM or the power chords internally.
Better to go to the technician in this case.
Your first Battery would have been fine too..
Apr 12, 2008 | Compaq Presario R3000 Notebook
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Less then 5 minutes runtime at minimal load
You gave no reasons why you thought it was simply a software setting, so I gave you a link below for some management software. The HP R3000 UPS supports HP Power Management Software (CPM) version 1.8. http://h18004.www1.hp.com/products/servers/proliantstorage/power-protection/software/legacy-software.html In addition the HP R3000 UPS also supports the LanSafe III management software (discontinued). My first question is: When were the batteries last changed? If they haven't been changed in 3 or so years, then it's probably low batteries, meaning they are old and cannot take a charge anymore. ZT3000 Beta tester of "0"s and "1"s
Jul 26, 2007 | Compaq UPS R3000 (242705-001) UPS System
Compaq UPS R3000 (242705-001) UPS System Logo
382 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
