Question about ASUS Premium Vista M2N32-SLI (M2N32-SLI PREMIUM VISTA) Motherboard
M2n32-sli premium vista edition motherboard
My motherboard refuses to boot vista after i install 6 gbs of memory. How do i solve this issue?
  • George Bill
    George Bill May 11, 2010
    I have researched several threads on this subject, some say the board requires a bios flash to the latest bios, another said start it wit 1 gig and see if it starts, then add the additional ram after the board boots up. I would try the ram trick first, in the interim I will poke around and see what else I can find. I am using an asusA8n32- sli deluxe myself so it intrests me as well since I was looking at your board as a possible replacement, good luck and let me know if the ram trick works.
  • 679 Answers
It's mismatched ram, get a stick or two from another machine, or a buddy, and try theirs out before spending money, it either blew of is the wrong speed, it appears that everyone is in unison on this, Good luck,Gym
Posted on Dec 22, 2008
    Sergeant:
    Novelist:
  • 183 Answers
"...refuses to boot vista AFTER (my emphsis) i install 6 gbs of memory?"
This portion of your question pretty much answers itself. The failure occurs AFTER you install more RAM. Therefore it's virtually a certainty the exact cause is either BAD RAM (as your web-thread poster correctly advised how to troubleshoot), or INCOMPATIBLE RAM (as "JSGRepair" detailed).
Good luck.
"Today's the best day of my life...and NOW you're part of it!"
    Scholar:
  • 130 Answers
I think you are mixing ram.... Use the same make and module for your ram... when you mix ram, the problem is other ram can be difernt Voltage. some 1.9V, 1.8V, 2.0V, 2.2V to operate. If you have 1.8V and 2.0V the computer won't boot. Hope this helps.
Posted on Dec 21, 2008
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: my m2n32-sli premium vista edition
Hi iimarceloii, did you check the FAQ section on Asus web site?
Using Vista 32bit/64bit edition or win XP;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=M2N32-SLI%20Premium%20VISTA%20Edition&os=24
Basically Asus wants you to use 2GB of memory until windows has been completely installed & completely updated before you can add more memory to the system.
Than you can increase your memory to 6BG. To see all the FAQ's from Asus, click on this link; http://support.asus.com/download/download.aspx?SLanguage=en-us
Type: M2N32-SLI into the search window & click the arrow button.
Good luck iimarceloii!
Merry xMiss
Mike
I hear 1 long and 2 short beeps and there is nothing on monitor
Hi Friend, I believe according to the beep codes you mentioned, it might be the issue with the graphics card!, So I would request you that if it is a desktop system, open up d cabinet and if there is graphic card inserted in the graphic card slot try reseating it.
That might fix the issue
Please let me know if it was of some help!
Dec 14, 2010 | ASUS M2N32-SLI Premium Vista Edition...
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
How do i turn my wireless capability on? Have an
*Wireless capability will automatically be on as lon as you have a wireless adapater or a wireless card or a built in Wireless in your motherboard that is properly installed to your computer
*you can check if the wireless card is properly install go to start - control panel network and sharing center and @ the left part of the window try to check if you will find Manage Wireless Network if not then the driver is not installed
*the driver of the wireless adater usually can be downloaded on the manufacturers website :)
Jun 30, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Motherboard will not power on. Onboard LED
did you check power supply? are there any beeps during post? is the fan running on the processor? did you try removing everything and reassembling to see if it works. let me know and good luck
May 02, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Feb 02, 2009 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
My m2n32-sli premium vista edition motherboard refuses to boot up when i put 6 gbs of memory. How do i solve this issue?
Merry xMiss
Mike
Dec 21, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Power start up itself after 10 mins
Check you start up settings it may be set to start from keyboard mouse or modem plus others even in the BIOS
Aug 08, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
New pc build
Yes windows needs to install one primary driver first and decide which is the primary display.
Nov 28, 2007 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
ASUS keyboard
u have problem with ur key board remove the dust in the key board its not problem with ur computer its a just ur keyboard
Oct 18, 2007 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
ASUS Premium Vista M2N32-SLI (M2N32-SLI PREMIUM VISTA) Motherboard Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
