The drive is not in system tray but is insalled.what steps do I use to start useing it
  • 26 Answers
Make the necessary changes in the bios setup indication the drive type ie SATA, ATA
Posted on Dec 22, 2008
How to replace waterpump
step 1. drain cooling system.
step 2. remove battery and battery tray.
step 3. remove drive belt.
step 4. remove water pump bolts ( 318 ).
step 5. remove water pump ( 300 ) and water pump gasket ( 314 ).discard gasket.
step 6. inspect and clean gasket mating serface.
step 7. install new water pump and gasket and tighten bolts to 89 in. lbs.
step 8. install drive belt.
step 9. install battery tray and battery.
step 10. fill cooling system.
Book time is 1.5 hours ( this one is what we call a gravy run ) good luck
Jan 13, 2012 | 2006 Chevrolet Impala
Installed new DG16D2S drive, the original would not read discs anymore. The problem I am now having is this: Upon start-up the disc tray opens, I put in a game, then shut tray with remote and it...
Here is a step by step instruction of how to change out your old or damaged drive!
http://www.ehow.com/how_5537596_install-new-dvd-drive-xbox.html
also this link will show you how
http://www.youtube.com/watch?v=-lexJIHYwo8
Sep 03, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
I have a sony computer, the model where every thing is built in behind the screen. a CD is stuck inside and i cannot remove. anyone have any knowledge on what to do to remove same?
The CD, DVD or BD drive tray may not open when trying to eject a disc. This can occur if there is a mechanical failure, or if there is a disk stuck in the drive.
Please follow the following steps to resolve this issue:
  1. Because some applications can prevent the drive tray from opening, close all open applications.
    NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
  2. Attempt to eject the drive tray using the eject command of the operating system.
  3. Restart the computer to the BIOS by continuously tapping the F2 key on startup and, while in the computer BIOS, press the EJECT button on the computer.
    NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
Sep 16, 2010 | Sony VAIO VGC-RB40 PC Desktop
My cd drive is brocken so i cant use insallation
Go to Belkin,com, click on support, click on routers. Now enter your model & info they request. You can download firmware,drivers & manuals. Also they have instructions on how to set up your router.
hope this helps.
Oct 18, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Insalling windows xp
As the pc is booting press F2 or Del (dependant on bios) and enter bios set up.
Choose to make your cdrom as first boot device, save settings and exit bios.
Insert cd drive before the boot up starts and there will bea screen prompt to "press enter to boot from cd", press enter and then the cdrom will go to the next step, asking press 'R' to repair or press 'Enter' to format and install windows, choose repair if you have documents you need on your pc.
The system will then go through a full repair installation, when complete your system will be repaired and everything should be as before with nothing lost.
You may have a faulty hard drive so if you cannot get windows to repair it will tell you theres no drive found.
Sep 10, 2008 | Computers & Internet
I am trying to scan a pic and my scaner says no scan options
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Jul 08, 2008 | Office Equipment & Supplies
External hard drive in winows
My guess is that the pc is trying to use a drive letter that is already taken. Make sure the drive is plugged in. Goto Start -> run -> type compmgmt.msc and hit enter. Click on disk management. You should see the drive in the list. Right-click the external drive and click change driver letter. choose a letter that is not already taken. that should do it..
Jun 13, 2008 | Microsoft Windows XP Home Edition
Dvd drive tray
I'm figuring you want to replace the Drive itself vs trying to put the tray back together? If so and you feel safe working inside the computer it's an easy job. here is the step by step link for it. just click on DVD
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1367033
let me know if you need any more help with it.
Oct 19, 2007 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
