Question about Acer Aspire™ T180 PC Desktop
Bios update I have an acer aspire T180. I just installed 2gigs of pc2 8500 ddr 533 and it only shows it as 400 so after some reading i flashed the bios. Now, I didnt realize that it would not flash if i did not turn off the bios protection in the bios when i first boot up but for whatever reason it still said it had updated it and needed to reboot. After it rebooted everything looked fine but no programs will work. no matter what I click on it just hangs. I cant even restart without pulling the plug. Any ideas as to what happened or how to fix it? Also, everything seems to work in safe mode. Thanks in advance.........Tim
  • tokicku Dec 21, 2008
    the problem is, it wont open any programs. Anything I try to open just hangs. I cant even open task manager. I cant understand it. It was working fine and the bios chip protection was enabled in the setup when i tried to flash it so im not sure what could have changed
  • tokicku Dec 22, 2008
    after you mentioned using restore i tried going in through safe mode and it worked. wow! I have been working on pcs for years and love em but damn they can make you crazy!! Thanks for the insight, i probably would have ended up doing a full format and reload instead of the easier obvious choice of restoring. Sometimes the easy choices are the hardest to see.
  • 679 Answers
Roll it back, do a system restore to yesterday or whichever day it was ok. You can go nutso trying to correct a bios problem, if you can get aroundit with a simple restore. You sound like you know how it's done but just in case ill run it down for you in the intrest of saving time. Start, Programs, Accessories, System tools, System restore, good luck, Gym
Posted on Dec 21, 2008
  • George Bill
    George Bill Dec 22, 2008
    so u can't even get in to safe mode? how about booting into the bios themselves with the delete key?
  • George Bill
    I am glad I was able to help, Have a gret night
I cant see my motherboard serial number it is acer model
its bios is flashed or reloaded , you should find original bios update by acre and flash it.
May 11, 2011 | Acer Aspire™ T180 PC Desktop
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Bios update failed *flash*
Did you make copy of your original bios before flashing...if yes then reflash with your original.
If No then trying reflashing again making sure no power cuts, dont touch computer until flashing is complete.
Are you using the correct bios for your MoBo?
Jul 04, 2009 | Acer Computers & Internet
No universal serial controller on my acer t180
Hi there. You need to update/install your chipset drivers.
This link will give you the chipset drivers:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=3703&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
You should notice that this driver is for XP. It should still work, but there is currently no chipset support for Vista on your product. If the above drivers don't work, then you can download the BIOS update from here:
http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1.att21k=1&CRC=3713735360
You will need to select your specific pc (Desktop, Aspire, Aspire T180), then click on the BIOS tab, download and install.
Hope that works
Mar 28, 2009 | Acer Aspire™ T180 PC Desktop
ECS 915-A(1.1) Ram Reading Issues
Is it a single ram module or dual ie. 2x 1gig ddr2 533?
What motherboard are you running?
Is it possible that you've given a static charge out while handling the ram?
Feb 27, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 14, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Ram DDR2
Hi Terry, you're board, PC Chips P23G only supports a max memory of 2GB. Please check pg. 9 of your manual, Installing Memory Modules.
Please be noted you can NOT use DIMM DDRII 1~2 (DDR2 533/400) and DIMM DDR1~2 (DDR 400/333) simultaneously. Only use either DDR2(533/400) or DDR(400/333) memory modules! (You should check the spec's of the other board before inserting memory that may not be supported). (You can damage the memory)
Click the link listed below for you're PC Chips P23G board.
Suggest you save this link to you're favorites.
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=92&LanID=2&DetailID=387&DetailName=BIOS
You will notice there is a fix for:
Patch code to fix REALTEK clock buffer sometimes couldn't detect DDR2.
Once there, click BIOS. Scrol down to the bottom of the page & read special notes. Than click the drop down menu & pick a download site. Creat a folder on you're desktop to store the download. Uncompress the .zip file. You will than have a folder named 070115 & a ROM file named 070115.ROM
This bios flash program requires you to use a floppy disk drive to flash the bios.
Follow the instruction at this link to flash you're bios.
http://www.motherboards.org/articles/guides/42_1.html
If you find to hard to folow you can pick another from this google search site.
http://www.google.com/search?hl=en&q=how+to+flash+a+bios+&btnG=Search
Good Luck! & Take your time.
Have more questions, feel free to ask.
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | PC Chips P23G Motherboard
I have bought the acer aspire t180 ro1-b4
Hi hurontoolman, everything you need for Win XP is listed here.
http://support.acer-euro.com/drivers/desktop/aspire_t180.html
Acer Aspire T180 PC Desktop. You might want to add this link to you're Favorites.
If I can be of more service, just ask.
Mike
Apr 12, 2008 | Acer Aspire™ T180 PC Desktop
Bios
download belarc advisory, run it...it will tell you bios company (which is where your bios update would come from) the current version of the bios...or you could download sandralite from sisoftware
Apr 04, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
411 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
