Question about GE Advantium 120 Convection/Microwave Oven
Microwave completely shut off, including the display
While using the spped cook mode the Advantium completely shut down. I checked that it was not a breaker in the house and voltage tested the outlet that the microwave is plugged into, and everything is fine. Someone told me that a common problem with these microwaves is the thermal fuse. I replaced that and still nothing. Any help as to what to try next would be appreciated.
  • 1 more comment
  • Jamie Winterstein Apr 09, 2007
    I will check them out, thanks
  • Anonymous Jan 07, 2009
    unit on bake, shut down completely.
  • Anonymous Mar 23, 2014
    FAN IS NOISY AND THE MICROWAVE SHUT OFF COMPLETELY, DISPLAY AND ALL WHEN USING FAN ONLY
    Genius:
  • 1,074 Answers
Check the diode and the cap they like to go bad.good luck
Posted on Apr 06, 2007
  • GE Master
  • 9,150 Answers
If it "completely shut down" then that sounds like it is "dead", which most likely means that the internal fuse, magnetron thermal cutout / thermostat, or cavity thermal cutout / thermostat went bad. These should be tested before replacing them to be sure whether they're bad. If they read open, they're bad. Please give us a little more detail on this failure.
Posted on Apr 10, 2007
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
I have a GE Advantium microwave model 2001 scb2001 03. It stopped working in the middle of a cooking and power goes completely out. A few days before that there was metal odor when using microwave
Betty, it sounds like you might have 2 problems and the power shutting off could be an end result of the metal odor you described. The power shutting off, more than likely is just a blown fuse. That is usually a simple and in-expensive repair. The metal odor could come from either your magnetron or from the high voltage transformer. Either one of those is going to be a rather expensive repair and if repair part stores in your area are anything like in my town, unless you repair them for a living or know someone who does, you can have some difficulty in getting those parts. Sorry for the bad news, but it might be simpler to just replace the microwave.
Feb 05, 2015 | GE Microwave Ovens
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
My microwave oven shuts down when set at high a high cooking number. I must wait a while before it can used again. I have a GE spacemaker
It may be that your magnetron is overheating, which will trip the magnetron's thermostat, which will interrupt power until it cools down a few minutes later.
Or it may be a defective magnetron causing electrical interference that disrupts the control circuit.
In order to help you, we need your full model number and some further information.
So please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
- How long does it cook before it shuts down?
- When it shuts down, does it go completely dead, or does it just stop with the display still lit?
- When you try to cook, do the inside light, turntable, and internal cooling fan all come on?
- Is it making any unusual noise?
- Is it louder or quieter than usual?
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
509 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
