Question about Intertherm P3RA-048K Air Conditioner
No heat My air conditioner on my unit went out via power surge back in the summer. A/C man came out and rewired the circuit board so we could have A/C but the heat would not work. He had to order in a new pc board. Since all of that happened, A/C man has gone out of business. Now no one wants to come out and fix what he messed up without charging the **** out of me. I already paid once and don't want to pay again, at least not yet. Can some one tell me how to rewire that pc board to get heat, otherwise redo what he messed up. Man it is cold in hear.
  • luckydollarj Dec 22, 2008
    It is 11 P.M. here in Texas and 14 degrees outside. I will do that in the morning and get back with you. Thank You for responding. Randy
  • Ken Bledsoe May 11, 2010
    Can you go to PC board and look at the thermostat wires what connection are they hooked to. I need to know what color goes to what letter on the board. okay? ken
  • 67 Answers
THERMOSTAT
Posted on Jan 07, 2009
  • 242 Answers
Hello , I think I can help , all you really can do is order a new control board and install it unless you want to keep rewiring it from heat to cool. They are fairly easy to install , you can order it on line with the model number off the unit spec sticker/tag. Hope that helps , good luck
Posted on Dec 30, 2008
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 04, 2011 | Goodman CKL42AR42 Air Conditioner
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
My Heat Surge was working fine, then it just went out. It is plugged in, but when I tried to start it again, it wouldn't light. HELP!
Tirn the Master ON/OFF switch to OFF. Unplug the unit for 12 to 15 minutes. This should allow the unit to reset itself. Plug the unit back in and turn the Master Switch to ON. If it reset itself, it should work normally. If it doesn't test the wall outlet it's plug into to make sure it still has power. Unplug the heater and plug in a lamp to see if it works. If it doesn't the circuit breaker in your homes breaker panel has been tripped and needs to be reset. More than likely, your Heat Surge Heater tripped the breaker, because of a malfunction.
Hope this helps solve your problem.
Mar 15, 2011 | Heating & Cooling
What could be the problem if for the past 3 years your heat pump freezes up during the winter months? A defrost control board has been replaced every year for these past 3 years
The defrost board is very easily fried by power surges...
Seems that over the summer the board gets toasted and you have to replace it...
a good commercial surge suppressor may help keep that from happening...
heatman101
Dec 14, 2010 | Heating & Cooling
Temperature setting rises up by itself no matter how many times you lower it back down to a lower setting manually or with remote. When the unit acts up like this it won't even let you power off...
Most window units are circuit board controlled. Most all electrical circuits like the fan motor, compressor, and heating, are powered through the circuit board, and distributed through different circuits in that board(control board). I would guess you have a circuit board malfunction. It's possible the thermostat is sticking, allowing the control board to misread a return air temp. Without some troubleshooting it will be difficult to pinpoint the problem but I'd bet it's one of the two.
Oct 10, 2017 | GE APH10AA Air Conditioner
The power to our house was down for a few days today, and when it was reinstated, my mitsubishi units did not come back on. I flipped all of the breaker switches, etc. Is there a reset button or something...
Sounds like a power surge "killed" the circuit boards. Get a professional to check. If the power company was responsible, lodge an insurance claim and get them to pay for the cost to repair the units. A surge will damage electrical components
Hope this helps I take the time to help you so please rate me
Feb 27, 2010 | Mitsubishi MSZ-A15NA Split System Air...
INSTRUCTION MANUAL /INTERTHERM FURNUES
usually a power surge will fry the transformer unless sometimes if your lucky the manuf. installed a fuse either in line or on the circuit board. 5 amp or 3 amp....any thing bigger wont protect your equipment.
Jan 09, 2009 | Intertherm P3RA-048K Air Conditioner
Defrost circuit board
he prob. jumped the reversing valve wire (usualy marked "O" or "B" on the stat and terminal board
(defrost board)
Dec 29, 2008 | Heating & Cooling
Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Sep 23, 2007 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
94 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
