Question about Pioneer PRO-510HD 53" Rear Projection Television
Upgrade a PRO510HD to handle HDMI?
Is there a way to upgrade my PRO510HD to handle HDMI input?
  • Anonymous Dec 26, 2008
    I'm on the same quest today after I'm looking at a new video recorder (from Pioneer) that has a HDMI output. I tried the Pioneer US and Canada web sites -- this television isn't supported on either web site. The TV does have a "RGB" input which it says should be used for HD connection but, what is RGB? Maybe there is such a thing as an RGB/HDMI adaptor? I intend to call Pioneer support when their holiday break is over.
Yes, just purchase this HDMI to HD15 (RGB) converter:
http://www.buy.com/prod/aitech-vga-to-hdmi-format-converter-1-x-hd-15-video-in-1-x-stereo/q/loc/111/209868752.html
Posted on Oct 02, 2009
  • nsaconsult Oct 02, 2009
    Sorry, this is the correct link.
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
    The link to the other device connects a HD15 device to an hdmi enabled tv. This unit allows you to connect an HDMI device to an HD15 enabled display.
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
How do I convert an HD tv that doesn't have HDMI to be able to use this format?
There are adapters that can covert the HDMI signal to a DVI plug, but at a price. DVI does not handle audio as does HDMI. Most devices that have HDMI outputs will not parallel the audio to allow you to use adapter plus audio cables. You have most likely come upon this issue of obsolescence in you current device.
Oct 22, 2015 | Zenith Televison & Video
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
My Connections From VIZIO 1080P & Laptop using HDMI But Is Not Working
If the firmware to HDMI is not installed, there will be no HDMI reception, although all the other inputs are OK. Contact the authorized service center. Software upgrade/re-install is a skilled work.
Jun 09, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Chromecast is not working with jvc hd52g886
Don,
The HDMI is best..but you need the standard HDMI cable. BUT this JVC is in the new Noah movie? Seriously, it wont handle Roku. The digital in function is strictly 480 p.
I think you will have to upgrade to a newer tv for this source
Mar 23, 2014 | JVC HD-52G886 52" Rear Projection HDTV
My HDMI inputs no longer work. The other inputs are ok. I hooked in a dvd player with HDMI out to make sure it wasn't just my satellite receiver and still it just says no signal. What can I do? Thanks
The only solutions u can tries is to unplug tv,satellite receiver box and plug it back in like about an hour later for the tv to reset itself and the sattellite box receiver to reboot and upgrade it softwares.Than go into the tv Menu go into the video setting and reset the whole tv Tuner signal board.This solutions have great chance for all the HDMI inputs to work again.If not have the same problems,sorry than those HDMI ports on the tv Tuner signal board are shorted and dead.These HDMI ports are putting on by a wave soldering machine when they are put onto the board.These HDMI ports can't be replaced individually or buy parts for it,almost impossible to replaces parts by hand soldering equipments either.The only solution now only is to buy a whole refurbish tv Tuner for the replacement,if u have to have those HDMI inputs for your tv,can't used other inputs to handle ur tv need to functions the tv the way u wanted.U some mechanical skills,like can take thing aparts and putting it back together.Yes.Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jul 25, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a sony bravia KDL52V51000 and today it decides not to read the HDMI inputs. just says no signal. it recognizes that there is something plugged into my 3 and 4 inputs but when i click each of them...
1. Please try a new HDMI cable.
2. Try to upgrade the FIRMWARE of the TV. You may download it from SONY official website if there is a upgrade for your model.
3. After upgrade the firmware, if the problem is not solved, change the main board.
Aug 11, 2017 | Sony Bravia KDL52V5100 Compatible Swivel...
I HAVE A LCD SHARP TV MODEL LC42D64U SERIAL NUMBER 806815957
try a software upgrade available at sharpusa.com find your model and download the software to a USB thumb drive then insert it into the USB port on the side of the set. enter into the menu go to "digital" select software upgrade and follow the promts. do not unplug or shut off the set until the upgrade is complete. if it doesn't recognize the software on your thumb drive try formating the thumb drive to FAT and not FAT32 reload the software and try again.
Mar 23, 2009 | Sharp Televison & Video
Cant get HDMI input to work
Hello Kman69,
You have one of two most likely problem.
(1) You have a defective HDMI board. This is most likely the case with your set.
(2) You may need to do a software upgrade. This is not common with the Sony, but i have done my fair share of upgrade.
I have the board in stock, just in case you need it. The software is available (free) and is very easy to do.
Best regards
circuitcity
Feb 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Pioneer PRO-510HD 53" Rear Projection Television Logo
450 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
