Question about Intel D845GVFN Motherboard
D845GVFN Intel PD MB audio issue HELP !
Hello, I have been messing with this for about a week now and unable to fix. I bought new cmop. speakers last week they are Logitech x-530. Got them for $20 could not resist! Anyways I hooked them up the same way my other ones where and did not get the 5.1 sound from them. So I wanted to get that true surround sound from them! So I tried to get an updated driver and well it screwed up the Intel audio studio program that was on the computer when I got it and now I had to delete the update but that really messed up the the audio studio. So now it dose not even show up on the desktop or any where on the computer. So what I need to know is how and where can I get this program and re-install it ? I have tried Intel's website but no luck . And I have looked all over the internet for it and could not find it ! I even tried limewire no luck just fake files ! Could some one help me out here PLEASE !!!! Thank You LS
  • Lloyd Stewart Apr 06, 2007
    Yep ! That's It ! But I can not find any where to just download that software at !!
    I have tried that too no worky .
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Check out this link: http://www.intel.com/design/motherbd/software/ias/index.htm is this what you are looking for? write back to see if it was. regards, Tom
Posted on Apr 06, 2007
  • Tom Schmid
    Tom Schmid Apr 06, 2007
    http://www.intel.com/design/motherbd/sof...
    This doesn't help you out any?
    You can d/l the software seperate from the drivers here too.
SOURCE:
Multimedia audio controller device error
Have you installed the audio driver? If so, please uninstall it and reinstall this... Intel D845 GvFn audio driver In case you haven't installed the audio driver, just download it and install it. This will fix your problem. You can let me know if you still have the problem. Good luck. Thanks for using FixYa.
Jun 06, 2010 | Intel D845GVFN Motherboard
Very sluggish and terrible audio when playing MP3's
check your computer RAM (random access memory) may be its not working first try to replace your ram then change your video card....
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Intel D915GAV Motherboard
I have a d845gvfn intel motherboard. wires at bottom beneith the battery were pulled out...wich one goes where?
I'll help you with this issue but it is advised you download the manual for the Intel D845GVFN MB. The manual is in pdf format. You'll need Adobe reader to view the manual. Adobe reader is free. Open the link for Adobe, download and install it; http://www.adobe.com/products/reader/
Provided next is the manual link from Intel; http://downloadmirror.intel.com/15211/eng/D845GVFN_ProductGuide_English.pdf
See page 11, Item O. See page 12 for description. (Auxiliary front panel power LED connector). If you setup the Front Panel Header as shown on page 31 item C. You shouldn't need to connect item D, Alternate power LED. If you're board does not power up than do connect item D.
Pin one should be positive and pin two should be negative. The wire colors define + and -. Wire colors do vary from case to case. Normally colors as red, blue and green are found to be positive. The color white and black are common for ground -. Check item C. You'll find a common color for each connection. This common color is ground.
On the odds if after you connect item D fails you can switch off the PS and switch the connectors. Item D and C use 5volt DC. A few seconds in the wrong position will not damage the motherboard.
Good luck
Mike
Jan 09, 2010 | Intel Computers & Internet
Need drivers for the mother board and other d845gvfn aac77641-104
You can download all the required drivers for your motherboard from:
Intel D845GVFN Download page
On the page which opens, select your operating system to download the appropriate drivers.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Oct 14, 2009 | Computers & Internet
How to instal agp slot in intel Board d845GVFN
AGP graphics adapter is installed only to an AGP slots not on the PCI.pci-mb.jpg slots as shown. You should change your AGP to PCI type graphics adapter.
Hope it works,
geloaa
Oct 08, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
My board is intel d845gvfn/d845pemy i need
try this link and let me know
http://download.cnet.com/Intel-R-82845G-GL-GE-PE-GV-Graphics-Controller/3000-2108_4-82808.html?tag=untagged
Please let me know how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Sep 26, 2009 | Computers & Internet
Dude i too have same prob :(
check in your bios configuration if the on-board sound card is enabled,if not enable it.your board is equipped with built in realtek sound card, if your driver don't work try here http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go%21
hope this helps, pls do let me know
Aug 13, 2009 | Intel DG31PR Motherboard
The original Intel motherboard(mb)in my PC which I bought from NACOM (N.Amer.Comp.Co. of Sunnyvale,CA in Nov.2006) failed and was replaced by NACOM with a later Intel mb. The original mb was id'd as...
hi:
please try to found the rigth driver or the last, for you sound card with the manufacturer of the motherboard, and in case that is teh driver that give you problem go to my pc rigth click manager , device, look for the sound device and under the tab drivers rollback the driver. best regards italocub
Jun 12, 2009 | Intel Computers & Internet
Maximum MB or GB of graphic memory supported by Celeron d 325?
you can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Drivers for intel desktop board D845GVFN/D845PEMY
Intel Intel Desktop Board D845GVFN/D845PEMY(01)
Driver Download
Oct 21, 2007 | Computers & Internet
Intel D845GVFN Motherboard Logo
184 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
