Question about Hotpoint VVSR1070D Top Load Washer
Stegnant water smell
My washer gives off a smell when in discharge mode , only first load when not in use for a while, after that its fine. plus there is water sloshing around when not in use. does water completely leave out of drum in discharge mode? ( faulty pump ?)
  • wbrazitis Dec 22, 2008
    i'l try thanx
  • Hotpoint Master
  • 3,463 Answers
It should completely empty the m/c.
If it is plumbed into your sink waste this could be cause of smell, also if it is connected to your waste make sure the hose is above the bottom of the sink trap,as water can sometimes syphon back into the washer from the sink. Remove hose from sink connection and clean and check for obstruction.
I doubt your pump is faulty.
If it goes into a stand pipe make sure this is not partially blocked, and again clean stand pipe with a strong disinfectant or similar
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
The washer smells. I have run 3 Affresh tablets and a bleach cycle and have left the washer open all night. However, the washer still smells. What else do I need to do?
Hi, I once experienced a similar, bad smell problem with my washer. What it turned out to be was a small sock being stuck in the water discharge pipe. This stuck sock eventually began to mold and subsequently smell. Once removed, my problem went away. Also, you can try running your machine with vinager or bleach with NO clothes. This weill remove any lingering oder. Hope this helps. Good Luck!
Jan 10, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
There is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
Mildew inside bellow.
is this a question? I will assume that you are saying that there is mildew growing below something, possibly the drum, inside the washer. The only way to definately get it out is disassembly and thorough cleaning. Check your discharge hoses to make sure they are not clogged, leaving water in the washer rather than discharging all of it. If you want to kill the mildew/smell, run an empty load or just some rags but throw a cup or two of bleach in the washer. The chlorine will kill the mildew growths. Run a rinse cycle or two before your next load of darks to get the chlorine out (especially if you are having a discharge problem) so you don't inadvertantly bleach your clothes.
Aug 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Model atf7000es1 front load washer
If the trap is fine I susupect your vent is probably restricted. If you have an inline vent ( a spring loaded rubber diaphram device at the top of the vent pipe) this part may have failed and need replacing if not have the plumber come out and rod the vent stack for the washer itself. If you are new to the area you may have a dual water system where the washer is ran off of a well and the rest of the house off a filtered source. The washer may have also been tied into a water header prior to the filtration system. In the Southern part of the US there are swampy areas that have shallow water wells that have a high sulfur content and give off the odor of rotten eggs, as I do not know your location this could be true also.
Hope this helps you.
Sep 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
Water Sounds
Friend,
ngfam1 At your service!
This is normal for the Neptune!
I used to have a Neptune and I sold them too!!
The machine is wringing out the clothes good??
The Neptune comes new with water in ti from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the mold, musky or even stinky smell of the Neptune! Every day i have people here asking what too do about the moldy wet smell!
SERIOUS!!!!!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
GOOD THING WHIRLPOOL JUST BOUGHT THEM OUT LAST YEAR!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint VVSR1070D Top Load Washer Logo
127 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
