Question about Dryers
Electric dryer intermittently doesn't heat
Intermittently, my RCA (made by GE) electric dryer doesn't heat. Sometimes changing the heat setting results in the dryer heating again, but sometimes not. Sometimes, it starts the drying cycle with heat, but then during the middle of the cycle, stops heating. My guesses are the temperature controller (or corroded connections), the thermostats (or corroded connections), or the heating elements themselves (or corroded connections), although my sense is that things like heating coils and thermostats are generally either good or bad, but don't intermittently work/not work. But, hey, y'all are the experts. Also, for GE dryers, how does one get to the thermostats and the heating coils? My old dryer (probably built close to 50 years ago), had a back panel that easily came off, revealing these parts, but the GE dryer doesn't seem to have a back panel that comes off.
  • Dryers Master
  • 8,220 Answers
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Posted on Dec 22, 2008
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
I have a ge dsxh47egww that until reecently worked fine. Suddenly it would rapidly flash the signal, extra care and start button intermittently and not work. Now it doesn't do anything. what is
is there an error code displayed,then check tech spec sheet located inside unit? if no code,try measuring between pins 1 & 2 on plug J-4 if you have 120volts a.c. its the control board,if 0 volts are found then its the door switch
Apr 26, 2012 | GE DSXH47EGWW Electric Dryer
Dryer heats intermittently sometimes doesn't heat at all, no pattern. Model # GLGQ332AS4
The ignitor is going bad...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Frigidaire Dryers
My dryer comes on but does not heat, have changed settings but will not heat
heatman101
Oct 20, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Dryer wont get warm... intermittently works... sometimes canhear the ignitor spark, sometimes not. Completely cleaned all of the lint in the machine, exhaust line, etc... and got alot of lint. Thought it...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
GE Profile Harmony Electric dryer blower issue - how do I access?
You have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Apr 21, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
286 people viewed this question
Top Dryers Experts
