Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidare ultra quiet
My top wash arm does not spay water. Not enough water pressure.
  • 32 Answers
You need a new wash motor, the impeller is stripped.
Posted on Dec 23, 2008
  • JJ Sep 24, 2011
    I had a similar problem and was able to fix it. Sort of a nonstandard approach, but it worked, and I did not need a repair man or any parts. Here is what I did at the advice of a friend who is also a handy man: I ran a few cycles with no dishes with CLR and Lime Away in the detergent and rinse aid compartments. Then I did one with Drano in the detergent compartment. Then I ran a couple cycles with just water to rinse it all out, and NOW IT WORKS! The top sprayer arm spins again, not all the time, but apparently when it is supposed to. And more importantly, the dishes are clean again! I noticed there had been some whitish grayish deposits on the heating element, and those are now gone. I think because of the Lime Away and CLR. After the Drano cycle, I noticed there were food particles that had splashed into the sink since my dishwasher drains into the disposal, as I am guessing most modern homes in the US do now. Anyway, before you buy any parts or call a repair man, I would give chemicals a shot!
Arms are sometimes not turning (intermittent) problem ?
Hi Gaetan, I am happy to assist you. Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. Another possibility may be that not enough water is being pumped to the spray arm. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Aug 13, 2013 | Frigidaire FPHD2491KF Dishwasher
Frigidare ultra quiet 1 top wash arm not cleaning properly
Hello ezideas - First I suggest verifying that there is enough water pressure coming into the unit and that it is at least 120F. Do you noticed if the spray arm will rotate freely or if it is damaged? If so, the spray arm assembly may need to be replaced. Connect with a professional to accurately pinpoint any potentially more serious issue.
Jan 14, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Dwd4311 dishes on top tray are not being washed, I think that it is not lining up with the top tray water outlet
I have some problems with my DWD4311 not giving clean results. It has improved it's cleaning ability if I push the top tray all the way to the back before switching on the wash. The water supply for the top spray arm is provided at the back of the washer and if the top tray is not pushed to the back I think a lot of water is wasted and the top arm does not get enough water pressure to do a good clean. I also think that this wasted water means that the water pressure for the lower arm is reduced also. So try pushing the top tray back as far as it goes before switching on. Good luck everyone.
Jul 01, 2012 | Beko Dishwashers
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Top rack of dishes no getting cleaned checked water tube to top rack its clear
there is a chance that the main washer motor is not supplying enough water to the upper spary arm.the possibilty that there is not enough water in the bottom of the unit during the time it fills up would cause this problem check your water pressure.if this is good then the main wash motor may need to be change
Sep 16, 2009 | Dishwashers
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
216 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
