Question about Dell Dimension 8300 PC Desktop
Dell dimension 8300 will not turn on with power switch unless computer is warmed up with a space heater. Then works fine, but must be warmed up longer and longer to start.
    Scholar:
  • 55 Answers
Then what you have is a defective Power Supply.
Posted on Dec 22, 2008
Dell dimension 8300 power switch will not turn on
You could have a faulty switch mode power supply.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 10, 2012 | Dell Dimension 8300 PC Desktop
Replaced battery in my Dell 8300 desktop now willnot reboot unless I turn printer of
plug in the printer into a different port and reinstall the printer driver
Jan 31, 2012 | Dell Dimension 8300 PC Desktop
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
I BOUGHT CHEAP RAM, EBAY, DELL DIMENSION 8300 HUMMING
This system supports ECC and non-ECC Rambus modules. ECC and non-ECC modules can be mixed but ECC feature will be disabled. Modules must be installed in pairs. multiple modules - PC800 the max is 2 GBs
systems tool...run disc clean up...put a check mark in every box, you don' need anything there as it is all copies you have elsewhere...
then defraggment also in system tools.
If you really feel like making that ole girl hum, do a complete reinstall using the latest drivers from the dell site. If you use your service tag number it will select the better drivers for your application.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8100&os=WW1&osl=en&catid=&impid=
go to this page for drivers (above) select your operating system (2000-ME-XP-Vista).
hope this helps you. Please leave rating
May 06, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Will not start
That's just about the opposite of what most systems would like. The colder they are, the better they run. There's a good chance your power supply is dying. Also, check and make sure the vents are not clogged with dust.
Dec 21, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
145 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
