Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Fan will not stop running once the TV has been turned off.
Once I turn off my Mitsubishi WD62725 the fan continues to run. What causes this and how can I fix the problem? Obviously this will cause the fan to go out sooner than it should. Thanks
    Genius:
  • 1,074 Answers
Check the circuit that the ean is getting its voltage from a diode, transistor,is shorted,or a resistor is open.causing the current to be flowing into the fan.
Posted on Apr 06, 2007
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
How long after burner is on should fan come on ?burner going out fan not coming on how to test fan or thermastat?
Your furnace has a fan delay relay that should turn the indoor fan on once the temperature gets up to about 150 degrees near the fan. The delay relay closes and energizes the fan circuit and opens once the thermostat is satisfied and the main gas valve turns the gas off. The delay relay keeps the indoor fan running for until the air temperature gets back down to around 100 degrees. If the fan delay relay stops working it will need to be replaced. Temporarily you can turn the fan to on on the thermostat and the heat should operate normally until the relay can be changed. The indoor fan will just run continuously. At least you will have heat.
Hope this helps
Feb 12, 2015 | Heating & Cooling
My r1 2009 is getting hot when im idle or in the stop light
1. make sure that the coolant is at the correct level.
2. when it is running hot the cooling fan(s) should be running or it will get hot. If the fan(s) are not running check the fan switch, fan relay, and the fan for correct operation. The fan switch should have continuity once engine is about 195+. The relay should click taken out of the system and 12 volts is applied to the smaller two relay terminal; at the same time it clicks, the larger two relay terminals should have continuity. Unplug the fan at the connector and apply 12 volts dc to fan side of the connector and the fan should turn on.
Jan 22, 2013 | Yamaha YZF-R1 Motorcycles
The fan continues to run. How long and will it automatically shut off?
The fan you refer to should be the fan in the oven cavity. It removes hot air from the oven cavity and expels the air out the front of the oven. Once the oven is turned off the fan will continue to operate until the oven cavity has cooled sufficiently. It may run for 10 to 15 minutes and will turn off by itself.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Car will not start, fan is draining battery I believe, not sure
boost vehicle but before you do that remove the fuse for the cooling fan till you get it to turn over once its running plug said fuse back in and get it to a shop to have them diagnose why the fan is on to long
Jun 02, 2010 | 2000 Volkswagen Beetle
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
The fans are continuing to run after the car is turned off
thats supposed to happen, its cooling your car down..it will shut off once the car is cooled down
Dec 01, 2009 | 1996 Ford Taurus
The radiator fan runs continuously after engine is off.
the temperature sender unit activates the fan
replace it! & get a new mechanic!!!!
Cheers Rob
PS:
im in AUSTRALIA & I just dont believe how much you guys get ripped off!
ITS STAGGERING!!!
Jul 20, 2009 | 2000 Renault 181
The electric radiator cooling fan will not turn off
As long as the fan eventually shuts off this isn't a problem,the fan will continue to run for a bit after the car is turned off,once it reaches a set temprature it will turn off.
May 01, 2009 | 1999 BMW 328 Series
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
