Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV turns itself off
On the front of my Song Wega is a small red light that reads "Stand By/ Tuner".  It began to flash repeatedly.  Now when I turn my TV on, I hear the volume and the picture is about to appear then it turns itself off after a few seconds.  I am connected to a Direct TV line with an older tuner but I have had no problems prior to this one.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the flashing indicates that the Sony KV-34HS420 has kicked in into protective mode. this is because the built-in diagnostics has sensed that a fault exists and turned the unit OFF to prevent further damaged. Normally, the flashing would be of a certain number/sequence. This number of blinks corresponds to an error code that would point to the general area of fault. Pls determine the number of flash/blinks or the sequence and post back.
This page may give you an idea on some of Sony's blink codes.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Unplug all the connections from the back of the tv for some time and also dosconnect the tv power wire from the mains for some time and reconnect it.and check out.if still the problem.then it could be the problem of main board in that any of the component getting over heated and the unit gets shutoff.that component has to be checked on the main board with a meter and replaced to make it proper.
Posted on Dec 21, 2008
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
WHEN TV IS TURNED ON IT IMMEDIATELY SHUTS ITSELF OFF. THERE IS A RED LIGHT FLASHING IN THE FRONT RIGHT CORNER BOTTON
The light is hte standby light and it should be blinking a repeating count. That count will indicate the defective circuit. Please post the count and confirm your model to be KV-27HS420 and we can look up the code and provide the probable repair solution.
Thanks,
Dan
Mar 02, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
May 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
Apr 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv turns itself off and on.
I just had this problem. The plastic back of the TV has a grated opening directly in the middle and towards the top of the TV. There is a fan directly behind. The grated opening was full of dust so air couldn't pass easily. I simply vacuumed the dust. I went the extra step and removed the whole back of the TV and vacuumed the entire space.
I assume the internal temperature exceeded its maximum so the TV turned it self off. Cooled enough to try a restart, heated up, ...
Oct 02, 2008 | Sony WEGA KZ-32TS1 32 in. Television
Stand by mode
How many times does the standby light flash...b/4 pausing and repeating ?
Dec 20, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
