Question about HP Compaq Evo Notebook N800c PC Notebook
Speed reduced suddenly
My machine started slowing down suddenly,fan speed varrying
Try to check the fan first. Oftentimes, the speed variation is a manifestation that the fan has accumulated to much dust. Clean it. If the problem persist try replacing it. The lack of proper ventilation inside the machine could hamper its normal routine thus slowing down the system.
Posted on Apr 06, 2007
When switched on, it starts At Maximum speed. You can`t slow it down to a slower speed.
If this is for a Mac and is after a hdd swap you will need to perform a SMC reset (google how to do as different for each model). If you have changed to a SSD you will need to download a fan control program and manually reduce speed of fans
Mar 06, 2018 | Computers & Internet
Whe sing router speed suddenly reduced and brushes started burning..changed brushes and bearings and problem persists.even tried bypassing switch yet it still behaves the same
Sounds to me that the brushes burned as a result of the low speed and the fault may actually be a winding's problem in the main com, insulation on the winding's may have broken down resulting in slow speed. I think this may be time to look for a new router on ebay it would probably be cheaper than getting the com rewound if at all possible.
Jun 27, 2014 | Bosch 1617EVS 2 Router
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
How do I control fan speed?
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
The fan speed on a laptop can determine how it operates consistently and reliably.
You can slow it down or speed it up, based on the circumstances.
For instance, slowing down the fan speed may be useful in reserving processes or during a prolonged slow time.
Speeding it up is beneficial in keeping the laptop cool during ongoing use or high-traffic times. For the long term, find a happy medium for regular use, so you won't "psyche" out your computer by constantly adjusting the settings.
Click on the Start menu and select "Control Panel." Next, choose "Performance and Maintenance."
Select "Power Saver."
To slow the fan speed, locate the slider next to "CPU Processing Speed" and slide it down by moving across to the left.
To speed up the fan, move the slider to the right.
Press "Apply" and then "OK," if prompted.
Hope this helps
Nov 08, 2012 | Lenovo IdeaCentre Q150 PC Desktop
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
How to have more mileage without compromising the power and speed???
Some of the general points are given below if followed will help you a lot on daily basis 1 Cut down on Static running of the engine. Reduce the idling time 2 Do not accelerate with out any reason when you start in the morning. 3 Fill the right fuel and oil. 4 Always run the vehicle on the recommend speed by the manufacturer which is given in the manual provided. 5 Avoid sudden burst of speed and then slowing down by sudden breaking. 6. Keep the tire pressure correct as less pressure burn more fuel and use more power. 7 Clean the spark plugs every fortnight. But once a month is a must. 8 Do not Overload. 9 Real good tip which you may not have been told i.e. When you reach the particular speed and are running it on for some time, reduce the acceleration. This way the vehicle will run without extra consumption of fuel due to the momentum it has already gained. This can cut down consumption fuel by 10 - 25 % depending on the nature of drive, short or long.
Dec 09, 2010 | 2008 Yamaha YZF-R15
Ceiling fan is controlled by dimmer
Yes, if the hot wire going up to the fan is coming off the dimmer, it is reduced voltage and will slow down. There maybe a separate hot from another switch??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
240v electric motor
Reducing the voltage is what you want to do -- this will effectively reduce the speed, without creating an annoying hum.
That said -- 110v is too low. Start higher. Half the voltage doesn't equal half the speed.
May 10, 2008 | Hampton Bay 24002 Ceiling Fan
Desktop
most likely your guess is correct and if a beep sound is not availabe (Power good signal) than its 100% power supply problem.
Apr 26, 2008 | E-Machines eMachines Desktop PC
HP Compaq Evo Notebook N800c PC Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
