Question about Philips Magnavox 51MP392H Rear Projection Television
PHILLIPS MODEL 64P842 HAS POWER NO PICTURE OR SOUND
TELEVISION WILL POWER UP BUT NO PICTURE AND NO SOUND. ALREADY REPLACED BOARD IT WORKED FOR ABOUT SIX MONTHS AND IS NOW NOT WORKING ANYMORE.
  • Edward
    Edward May 11, 2010
    Do you hear a chirping sound?
    Which board did you replace before? Was it for the same problem or a different issue?
    Scholar:
  • 38 Answers
I hate to say this, but this is why I've been trying to tell people here not to fix these sets. This is EXACTLY why I don't repair Magnovox any more. They just don't hold up to repairs. Those sets can have a bad small signal board or a power/deflection board. I'm sorry your having problems. Sound like the power/deflection board is working since you say it powers up. Some of those sets have a "daughter board" that plugs in on edge of the signal board "SSB" that go bad all the time. All the video and sound go through it. Just cut your losses and don't spend any more money on it. I hope it's something simple for you, but I'm affaid it won't. Good-luck.
Posted on Dec 24, 2008
  • Chrisry696 Dec 24, 2008
    If that is a 64P8342, the part# for an SSB moduel is 3139 127 25871 and cost around $200.00 or more. VERY common failure part. This will cause exactly what you describe. Will also cause all sorts of funky systoms as well.
Have sound but no picture. turn of and on again, then normal picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 22, 2015 | Televison & Video
I have a 42 " Phillips with no pic and no sound. I've replaced the Power Board and CT Board tht corrected the error blinking lights but still have the problem My Light stays solid green and I
Dear Mate
Please share us the Model # and Is that is the Plasma LCD or LED. And tell us Is your`s TV is stay on stand by or its green LED is stable.With No video and sound.
Dec 11, 2014 | Televison & Video
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
PHILLIPS 51PW9363 SOUND BUT NO PICTURE. ALREADY REPLACED HIGH VOLTAGE TRANSFORMER NOW TWO TUBES GLOW AND ONE ARCS IN THE TUBE BUT WONT GLOW IS IT THE TUBE OR SOMETHING ELSE?
The one that is arcing may be bad...slowly take the board off the bottom of that tube...then power on...If the other tubes light up again you found the problem.
Jun 17, 2009 | Philips 51PW9363 51" Rear Projection...
Phillips projection TV no picture, no sound
can i purchase the entire convergence board ihave double image tried to change the stk-120's the rear one broke now i have no picture or sound but the power show's on
Dec 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
