Question about Philips SWV6813-17 HDMI 3-Way Switcher
Switcher will not recognize multiple inputs
The switcher will recognize the sony blu-ray player, regardless of position, however it will not recognize the computer or the DVD player when hooked up to the other 2 inputs. It recognised the macintosh computer only once where I could switch between the sony and the mac. Hasn't recognized computer since.
SOURCE: transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Posted on Nov 25, 2007
SOURCE: WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Need To Unlock My Sony BDP-S500 To Play Imported DVDS And BLU-RAY
It is illegal to change the zone on a DVD or Blu-Ray player. You should invest in what is called a Multizone Blu-Ray Player - it will play any disc from any region. That is the only legal answer I can offer. YouTube does, hoewever, feature hacks on unlocking the region code - but it is still illegal.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: HOW DO I ADD A BLU RAY PLAYER TO PHILIPS HTS6500
If there is some type of audio cable running directly from the Vizio to the HTS6500, then you can just plug the Blu-Ray player into the TV and you're set. If the current audio cables are running instead from the cable or sat box to the HTS6500, then you will need to run audio cables from the Blu-Ray to the Philips HTS6500. There are 3 available audio slots on the Philips - the Digital Audio/Coaxial IN, AUX 1, and AUX 2. If the Digital Audio slot is already taken, then you will have to run red and white cables from the Blu-Ray player Audio OUT to either the Aux 1 or Aux 2 on the Philips (I am making a huge assumption that your Blu-Ray player has red/white audio outs). If the Digital Audio slot on the Philips is not taken, then run a digital audio cable from the Blu-Ray to the Philips. Good luck!
-Tha Mp3 Doctor
Posted on Jan 02, 2009
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
Can i watch netflix through my bluray player on my bravia 42 tv with a 4 port hdmi switcher
If your blu ray player supports Netflix and you can connect the blu Ray player to the TV then yes you can!
Aug 07, 2015 | Sony Bravia 42" 1080p Flat-panel Lcd Hdtv
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
How do I create a login to the You Tube app on a Sony Blu-ray
You would create a login with a you tube account regardless of the other device. Just follow the screen prompts on the Sony.
Sep 07, 2014 | Sony BDP-S390 Blu-ray Disc Player BDPS390
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
May 16, 2011 | Sony BDP-S350 Blu-Ray Player
My sony blue ray player is only playing DVD's but will not play blue ray disks. i have tried multiple disks
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
Nov 25, 2010 | Sony BDP-S350 Blu-Ray Player
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Oct 10, 2008 | JVC HD-70FH96 70" Rear Projection HDTV
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
Philips SWV6813-17 HDMI 3-Way Switcher Logo
55 people viewed this question
Top Philips Cameras Experts
Mohamed Ismail
Mohamed Ismail
Prashant Hattangadi
Level 1 Expert
Are you a Philips Camera Expert? Answer questions, earn points and help others
