Blue tint on projector.
I have an Optoma Movitetime DV10 projector. I have had it for a few years and its worked without any problems. But lately, after about 15 minutes of use, everything gets a blue tint. After turning it off and on again, it works fine, but after another 15 minutes, it happens again. Any help?
  • 1 more comment
  • tconologue Dec 22, 2008
    We are having the same problem but the blue tint is in the middle of the screen and does not go away.
  • wmignucci Jan 05, 2009
    I am having the same problem.  Peoples skin color are all coming up blue.  Any suggestions on how to fix it?
  • Anonymous Jan 21, 2009
    A blue haze in one corner is affecting the picture output.
We had this issue. We switched out the cable & it worked fine.
Posted on Apr 10, 2009
    Problem Solver:
  • 5 Answers
I've given a suggestion for another user which may is applicable to you. It can be found here by using the search phrase- "Blue tint on projector" (not your topic) or by clicking my name and the appropriate topic.
Posted on Jun 11, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: Blue tint on projector.
My DV10 problem was as follows: After 10-15 minutes the picture would gradually change tint toward the green/blue/purple and the smooth color transitions would also change to harsh obvious transitions. No control adjustments could compensate for this problem. Turning the unit off for a short while and turning it back on would repeat this process
After doing a bit of research I determined the most likely culprit was the color wheel. Since the unit is out of warranty, I opened up the case and, wearing surgical gloves, removed the color wheel. As I suspected it was a bit "gummy". When I manually tried to give it a spin it was somewhat stiff. I got a syringe I keep around just for this sort of application (I work on PC's) and sucked up a few drops of household 3-in-1 oil and then carefully directed it into the cavity back (opposite the glass color wheel) while carefully rotating the unit in my hand to disperse the oil evenly. The front, (color wheel side) is closed so adding oil there does nothing. I carefully spun the wheel manually for a while, reapplied another drop or two of oil, spun it again, and it soon loosened up quite nicely. After blowing out the dust, I reassembled everything and tested the unit out for a couple hours. So far so good. No issues at all.
I'm going to try to give dis-assembly instructions but I'm doing this from memory so in no way is this meant to be an exact step by step guide.
1) Remove 6 screws from bottom of unit. (I'm not sure if this step was necessary but I also removed the lamp at this time.)
2) Remove the two screws from DVD bay.
3) Using something like a small flat tip screwdriver, wedge and remove the DVD bay door. There are 2 plastic protrusions which act as hinge points. Carefully flex the door near one of these until you can slide the door out. Remove the spring from the door. NOTE: Its common sense, but be sure to examine how it was inserted so you can put it back together correctly.
4) Remove the last screw holding the cover on- which should be visible once the door is removed.
5) You should now be able to lift the upper circular portion of the unit but only partially as it is attached by ribbon and wire connections. These will have to be carefully disconnected. You release the clamping mechanism on ribbon connections by gently wedging the ends up, alternating ends until the ribbon comes out quite easily. Employ a similar tactic disconnecting the plastic wire connectors. Never pull on the wires or ribbons with anything more than the gentlest touch. Untape any wires or ribbons from the metal surface, leaving the tape in place for use during re-assembly.
6) Remove the screws attaching the top metal plate and lift the plate while freeing it from the wires and ribbon by carefully threading them through their corresponding slots.
7) What and where the glass color wheel is should be obvious now. There are 2 screws attaching it to the frame and 1 screw attaching a circuit board to its mount. Carefully remove these.
8) Carefully remove the 3 screws holding the mount to the color wheel unit. NOTE: During re-assembly, remounting this must be done with the proper orientation or it will not re-mount to the frame correctly, so be sure to notice the orientation.
9) Carefully apply oil as described above, or in any similarly accurate way. Loosen the glass wheel by gently rotating it- being sure to only contact the edges of the wheel.
I advise you not to touch the glass surfaces at any time. I would also suggest you do not attempt to clean it in any way, other than perhaps using some compressed air to remove dust. I noticed some slight discoloration, or fogginess might be a better description, but I did not attempt to clean it, and after assembly, the picture looks good. I took this opportunity to give the entire DV10 unit, especially the fan, a good blowing out with compressed air. If you check the fan and notice it seems a bit gummy, you may want to remove the label (mine was Sunon) and apply a drop or three of oil to the axle while manually spinning the fan to help get a thorough dispersion. You may have to tilt the unit to direct the oil as needed. Be sure to tape the area the label covered as it acts as a dust preventative. Try to apply the tape uniformly (symmetrically) as it can have the slightest affect on the balance which over time may cause undue wear.
10) Reassemble the unit and if you are anything like me, instantly remove your sweaty hands from the surgical gloves and go wash them. Now test the unit.
Remember, patience is always required when attempting this sort of repair. Never force anything. If you find something isn't responding as I've described, do not force it. As I've said, I recounted these instructions from memory and perhaps I missed a screw or a step. I disassembled this unit without any instruction at all so I'm confident if you proceed with patience, caution, and some common sense, you too will be successful. Of course, I take no responsibility for any problems which may arise from following these suggestions. You use them at your own risk.
For those who need to order a new color wheel, the part is #70.81R26GR01 and is costs $129.00 US + shipping from the service center shown in the info below. In case these instructions seem too unclear or beyond you, and you just want to send the unit in, I've included a generic support email below.
Good Luck.
Timogin
(Quoted from an email)
In response to your inquiry: All units that come to service must have an RMA number and there will be a $160 prepayment fee per unit. Packages without RMA number may or will be rejected. If you wish to send your unit for repair, please complete the attached RMA Request Form and fax or email it to back us with your signature. Once we receive your information, an RMA number will be issued and will be emailed or fax with shipping instructions.
If you wish to go ahead with the repair, the labor is $100 per unit plus parts. $160 prepayment fee will go towards the labor and return shipping – SIGNATURE REQUIRED.
If you wish not to go ahead with the repair, you will be charged $160 prepayment only per unit.
The turn around time to evaluate the unit and to email or fax the repair estimate is between 1-3 business days. Our turn around time to repair the unit is between 2-5 business days from the day we receive your authorization and maybe longer in case of part shortage.
If the prepayment of $160 is being made by check, we will need a copy of the check to issue an RMA number. Please make Check payable to Technical Service Corporation (subsidiary of Optoma Technology, Inc).
Please note that we do not accept P.O. numbers unless your Company or School has an account with us. If your Company or School has an account with TSC, simply fax us a copy of the PO with the amount of $160.00 along with the RMA request form to issue an RMA number. P.O should be payable to Technical Service Corporation (Subsidiary of Optoma Technology, Inc).
NOTE: Pre-payment will not be charged until the end of process.
If you have questions, simply email or call us between 7:00 am to 5:00 pm PST.
Thanks,
Alma Gutierrez
Customer Service Representative
Technical Services Corporation
Ph: (408) 435-3957
Fx: (408) 383-3711
Blueish Red display after 15 minutes optima dv10
In response to the same problem another person had I've given a self-repair suggestion which can be found here by using the search phrase- Blue tint on projector or by clicking my name and the appropriate topic.
Jun 11, 2009 | Optoma MovieTime DV10 Multimedia Projector
When bulb turns on it gets a loud humming noise
It's likely the fan or the color wheel as both of these spin. I've given a suggestion for another user which in part may be applicable to you. It can be found here by using the search phrase- Blue tint on projector or by clicking my name and the appropriate topic.
Jun 06, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 Issues
change the lead that came with the system to another one, i am not sure if it was the new cable or the step down in the amp that I used, but it did the trick
Dec 10, 2008 | Optoma MovieTime DV10 Multimedia Projector
I have the same issue, I have figured out its a fan issue, my fan must have went out. After about ten minutes the bulb will get too hot and the picture will start to turn a way off tint color. I put a fan on my projector and after about 40 min. the picture returned to the appropriate color. I am still investigation on how to get and replace the fan.
Sep 02, 2008 | Optoma MovieTime DV10 Multimedia Projector
Colors not right on DV10
i had same problem so i opened up the casing of the projector and blew the dust off the inside components. it has been two days without the problem and the picture quality is better. probably an overheating problem due to all the dust. just be careful when taking it apart because there are a few cables to disconnect and a bunch of hidden screws, if it's still under warranty or you don't feel confident taking it apart, i'd send it in to get fixed.
Aug 09, 2008 | Optoma MovieTime DV10 Multimedia Projector
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
Jul 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Dvd player
Hi
Just want to let you know that after i perchased my dv10 from USA it was locked to region 1 and will not play dvds from UK.
I succesfully unlocked it with a hack but again it stopped playing dvds from the UK after 2 years and soon i play dvd it will say"no disc".
I wrote the hack differently and succesfully unlocked it again.
no problems since then.it plays all regions.
anyone need help can email me on
kakool@talktalk.net
May 12, 2008 | Optoma MovieTime DV10 Multimedia Projector
Picture turns blue
bad Lcd's i guess get the projector looked at immediately before something worse happens
Jan 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
3,394 people viewed this question
k24674
jasbo
jasbo
