Question about Braun Tassimo Espresso Machine/Coffee Maker
UGH! Leaky product, weak coffee in very small portions
I was so excited to be able to brew cappucino and espresso quickly and easily in the morning. Unfortunately, this product doesn't seem to actually brew because the product is weak and the portion is smaller than an espresso cup! Also, there is a lot of water in the return cup and the machine leaks all over my counter. When brewing, it splatters coffee-colored drops all over. I am so disappointed. Also, how do you get in touch with Braun customer service? That's another impossible task, it seems. Help!
  • trevor3007 Nov 26, 2007
    this must be a design fault as i had one previously & it did leak in the same place??? leaks when NOT in operation & always on the same side!!!
  • Anonymous Mar 15, 2014
    My braun coffee maker leaks when brewing. The coffee leaks from the basket and does not go quickly enough into the top cover. I just bought a new top. It would happen from time to time but now it is more frequent.
    Genius:
  • 1,074 Answers
Thats a tough question my brother.but you can try wwwbraun.com and see what you get.good luck.
Posted on Apr 06, 2007
My Tschibo Caffissimo Classic will not let coffee come out of the spout, why?
Clean the port using a small paper clip. Push it up the tube and pop out the material that collected inside.
Always use Distillate or Filtered water.
Feb 02, 2015 | Coffee Makers & Espresso Machines
Steam comes out from the tray grill
Sound's like you have a crack somewhere in the tray,
You could try locating it and sealing it.
Jan 15, 2014 | Jura Capresso Impressa F7 Espresso Machine
I bought a Krups 867-42 espresso cappucino maker from a second hand store. I need instructions on how to make espresso and how to froth milk. I have the necessary coffee pot to brew regular coffee, but...
Hi austyn90211,
Welcome to fixya!
Here is the user's guide to your espresso machine: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035208.pdf
Enjoy!
Handie Andie
Jul 15, 2011 | Vacuums
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
My miele espresso maker dispenses too much water in my espresso. how do I fix this?
If you fill two esspresso cups at the same time it should be the correct size. But if it is weak, see below...
For one cup, press the small coffee button to start. Press the button again when the desired amount of espresso is in the cup to stop the flow. if it is too watery but the correct amount see below.
If the espresso is too weak push the coffee grinds slide switch inside one notch finer and make another 3 cups. If the flavor does not get strong in 3 cups then there is an anomaly happening. The brew unit upper filter has gunk clogged behind it to a point where the pressure (230psi) of hot water trying to get through the gunk pierces a small channel through only a portion of the filter screen. All the water is running through only 4 or 5 holes in the filter screen. This eddy allows hot water to pass most of the grinds without extracting flavor. It's the same as if you clogged a sink strainer then pushed the blockage off part of the strainer. The water goes around the coffee not through it. The path of least resistance.
Remove the upside down stainless steel filter on the brew unit- Remove the screw using the allen key that came with the machine. It goes through the little finger nut on the top of the brew unit. Turn it counter-clockwise (lefty loosy) and the filter will come off from underside. The area behind the filter screen has to be cleaned of any coffee residues. Also check thew creme valve. It is under spring tension accessible from the top of the brew unit by removing two screws holding the long pipe on top. be careful not to let the spring shoot out and loose the creme valve. It looks like a plastic rivet on the other end of the spring. Clean out the entire channel by rinsing. Use a pipe cleaner for dried on grinds.
Note: the finer you set the grinds the quicker it clogs the filters. Increase the use of cleaning tablets when you grind finer coffee. A clogged brew unit is almost impossible to clean even for the most handy of people and the last I checked a new brew unit is well over 200 bucks! Good luck!
Jul 30, 2009 | Miele CVA615 Espresso Machine
Inconsistent quality of crema and coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Sep 19, 2008 | Gaggia Titanium Espresso Machine
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Coffee is weak / Is pump supposed to kick on and off during brewing or run steady
Aug 26, 2008 | Krups XP4030 Espresso Machine
Weak Coffee
Mar 02, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Braun Tassimo Espresso Machine/Coffee Maker Logo
488 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jim Goldsmith
Jim Goldsmith
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
