Question about Acer AL1916W 19" LCD Monitor
Open back cover on acer lcdAL1916W
How do you go about removing back cover to repair board on the acer
  • 3 Answers
Use the Acer AL1916v service guide as well as the Acer AL1916p service guide to disassemble the monitor. These can be found as PDF's using Google. Please note that disassemling the internal EMI perforated metal cover nor the electronics shown are for the 1916w model.
I fixed a 1916w that had a bad power board.(Delta A190E2). I replaced two blown 1000micro farad 25v dc electrolytic capacitors made by CapXon. Other people have had similar problems with this and other brands so do not use them as replacements.
To remove the back cover you must Remove the basse stand and the five screws holding it down. Now run your fingernail along between front and back covers. There are five catches on the top, four on the sides, and six on the bottom. Two of the cathes are at the corners of the plastic surrounding the control button module.
If you can get to the EMI shield you must first pull out the four connectors that go into the perforated EMI cover. I used my fingernails to gently pull them out by pulling and rocking these small white connectors. Do not pull on the wires. Next take out the four screws holding the EMI cover. You must also take out the two screws on the AC power connector as well as the two lugs on the video connector since they are screwed into the EMI cover.
Take the control panel circuit board out of its clip noting that the ribbon cable is lightly glued down in one spot. Rotate the ribbon cable and attached circuit board up vertically so as to clear the metal panel holding down the bottom of the EMI cover as you rotate this cover up 45+ degrees. Once clear of the EMI cover let the ribbon cable rest on this metal cover as you lift the EMI cover up vertically. Note the metal tabs coming up from below the two conectors. These must be kept below the EMI cover when it is replaced so that the screw holes line up. Once the EMI cover is removed lay down the lower metal plate making sure you clear the ribbon cable and put the control circuit board on the cables end back in its clip to protect it from accidental damage.
The power board and video board can now be examined. If you see domed capacitors on the power board you can remove the board by removing the four screws. Take hold of the board and gently pull and rock the board from side to side as you pull the multipin male connector out of the female connector on the video card.
Fix the power board by replacing any blown capacitors (domed tops) and reinstall. Reverse the process decribed above puting the monitor back together. Note that before screwing on the back cover first snap the front and back covers togther using your fingers.
Have a merry Christmas and new year.
Posted on Dec 23, 2008
My Acer AL1916W LCD does not show full color. The half of the screen show one color while the other half display normal color that am expecting. I don't know how to correct it. I have use the setting...
More likely to have failing T-CON board which is part of the LCD panel assembly, you can try reseating the ribbon cable attached to the LCD panel's T-CON board first, otherwise new panel will be needed.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Corporate Computer
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
I have an Acer AL1916W the power switch lights up brightly but when computer is switched on switch goes dull and and screen stays blank...Found two Capacitors that were bulging they were 220mf 25volt....I...
Can you send me a picture of the boards in your monitor? We work on Acer units all the time.
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Acer AL1916W 19" WideScreen LCD Monitor
No backlight. I'm looking for a schematic for the acer al1916w with power/inverter board dac-19m0005 rev: 01a bf.
<p>How about the whole <A href = "">Service Manual</a> ?</p?
Jun 14, 2009 | Acer AL1916W 19" LCD Monitor
Have an acer al1916W. The screen is all white. Can't get back off
open your item and recheck/reseat the cable connecting the mainboard to the LCD screen. If problem persists, maybe its a mainboard problem
Apr 06, 2009 | Dell E153FP 15" LCD Monitor
Schematics are in the Service manual here →
Oct 12, 2008 | Acer AL1916W 19" LCD Monitor
It is inside the LCD the at the main board. You have to repair the board to make it function.
Apr 19, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W Beeping
Try setting to the native resolution of 1440 x 900.
Aug 06, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
1,653 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
