Question about StarTech.com StarView SV211K 2-port KVM Switch
THE BOX NOT REDIEVING CHANNELS
HI MY BOX STOPPED WORKING WAS SCANNING ON CHO---CORK I HAVE DVB-C TRUE CABLE BOX ANY HELP
  • JMBURKE02 Dec 22, 2008
    THANKS BUT EMU IS TURNED ON STILL NO CHANNELS
  • Anonymous Feb 27, 2009
    Fix my box!
    new code not workin. THE BOX. does anyone know wat to do?? xx
    Problem Solver:
  • 15 Answers
Nnew codes for cour...cork
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} (00) CE 19 2E 87 80 61 74 90
(01) 62 FA D9 F3 CE 05 FA 79
hope this helps
Posted on Dec 22, 2008
    Problem Solver:
  • 23 Answers
Dont know if this will help press menu then 1570 on remote check emu see if its on if not turn to on
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Hi I purchased a Sony 60 inch T.V model KDL60EX703U. It is supposed to have built in free view. I have set it up the same as my previous t.v however when searching for channels it does not find any. ...
When you are searching for channels check what setting the channel search is in this model had DVB-T DVB-C and DVB-T2, If it is in the wrong search mode it will not find the channels. Also does your sky decoder use a dish? if yes then this could also be the issue as the TV uses Terrestrial signals and the SKY decoder will use a Satellite System.
Oct 25, 2010 | Sony Televison & Video
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
No channels after scanning analog cable on Hauppauge 1600
I have exactly the same problem with the very same equipment but I may have found a solution. Try scanning for DVB-T channels and you may find some success. I also recommend printing up the WinTV user manual and reading it. I'm not big on reading manuals but this one actually has a lot of useful info. I will try to fix my setup and let you know if it works. Today it is recording all 6 Star War episodes till 2 am plugged in through the set top box (can't interupt)
Feb 05, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Starview 4 not receiving channels
Hey there Mr Mclone,
Here's the newest firmware driver for your Starview box, mate:
http://www.4shared.com/dir/3042613/f6e3421c/sharing.html
It's in the firmware folder. Download the lot. The upload the box usb bin file, and select automatic scan.
Good Luck and Season's Greetings to you!
Chris (ziraffa)
Dec 22, 2008 | StarTech.com StarView SV211K 2-port KVM...
Need new codes for 'the box' for CHORUS or CHORUS CORK
5E 01
01
AA 26 9E F2 E9 14 D1 AE.
NEW CODES FOR CHORUS AS OF APRIL 3RD.HOPE THATS OK FOR YE.works in cork so that should be ok for u jim.enjoy all
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
The box chorus codes??
*CHORUS* (5e 01)
00 = CE 19 2E 87 80 61 74 90
01 = AA 26 9E F2 E9 14 D1 AE
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
57 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
