Question about Danby DCD5505W Electric Dryer
Kenmore dryer trips the breaker
Our kenmore dryer is tripping the breaker and the wire leading into the breaker is burnt. What does this mean?
    Sergeant:
  • 359 Answers
THE PROBLEM COULD BE THE CONNECTION TO THE BREAKER ITSELF , BREAKERS ARE SET UP FOR CURRENT OR AMPERAGE SURGE AS WELL AS THERMAL IF THE WIRE CONNECTING TO THE BREAKER IS LOOSE IT WILL HEAT UNDER LOAD AND CAUSE THE PROBLEM YOU DESCRIBE , TURN OFF THE BREAKER AND RE TIGHTEN THE SCREWS AND IF THE TERMINALS ARE DETERATED MIGHT NEED TO REPLACE THE BREAKER IF POSSIBLE CUT THE DAMAGED PORTION OF THE WIRE CONNECTING TO THE BREAKER STRIP THE END AND RECONNECT
Posted on Dec 22, 2008
  • Allen Neal
    Allen Neal Dec 23, 2008
    HOPE YOU DID THE INSPECTION I ASKED VERY IMPORTANT
My dryer is an lg tromm dle7177rm. it is 220v. it has ran fine for 3 years but now trips the breaker within 5 min.
If your breakers are old. I'll start by replacing the breaker to the dryer at the box. It is a common failure. Breakers wear out to. Check the power cord for any burnt markings and look at the outlet as well for burnt or discolor contacts. This will overheat as well causing the breaker to exceed the limit and trip it.
Nov 05, 2015 | LG Dryers
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Keeps knocking the electric off in the whole house
I would guess it is a short> possible causes:
1) outlet: turn off breaker to outlet pull cover off and look for burnt or loose wires
2) dryer cord: take back metal plate off of dryer look for burnt or loose wires
3) heating element
4) check all internal wiring for burnt or loose connections
The breaker for the dryer should be a 30 amp breaker, and should only trip that breaker. If it is tripping the main on the panel then something else is wrong. You will need to pull off the panel the the breaker box and pull out the dryer breaker and look to see if it burnt, make sure the wires are tight on the breaker, you may want to try a new breaker also. Hope this helps Tim
here is a website that may help:
http://www.applianceaid.com/general.html#fuse
Jan 09, 2011 | Hotpoint Dryers
When I turn on dryer, it automatically trips the breaker and a loud boom is heard.
unplug dryer, throw breaker on, if it trips then it is not the dryer: outlet,house wire, breaker or panel leg is bad. Next is inspecting dryer cord for shorts, dryer cord connection to back of dryer, heating element, wires inside dryer, etc. Loose or burnt wiring. Here is a website with some helpful info. Hope it helps, Tim:
Dec 02, 2010 | Maytag Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
G.E. electric dryer terminal block and wires are burnt. I took the dryer apart to clean the inside of dust and lint. I put it back together and plugged it in. The breaker tripped,and I looked at the...
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Mar 13, 2009 | Kenmore 64902 Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Danby DCD5505W Electric Dryer Logo
153 people viewed this question
Top Danby Dryers Experts
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
David Emmel
David Emmel
Are you a Danby Dryer Expert? Answer questions, earn points and help others
