Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Flashing code 99
My Rinnai is flashing code 99 ... I think I am out of propane but thought I would check anyway.
  • Anonymous Jan 01, 2009
    Do you know what code 99 is? First time problem with 3 month old unit. Its cold!
  • rbgas Jan 07, 2009
    for me the flashing 99 was an indication that I had run out of propane.
    Novelist:
  • 126 Answers
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 10, 2009
  • 1,420 Answers
Bad pressure switch or a bad sparker board.
Posted on Jan 05, 2009
  • Chandler Ede
    Chandler Ede Jan 08, 2009
    Sorry to disagree but Page 12 of the installation manual clearly indicates otherwise.
Rinnai code 99
i am not an expert. this is how i fixed my rinnai code 99. my rinnai 100 4f would run for few seconds then the red light would continue to flash. code 99 would come up.i took the unit out of service. i notice that the fresh air hose had two very small hoses located on it's elbow had been switched around when i took it to be serviced. the unit worked well. how ever. i changed my mind when i realized the service was not need. anyway the two small hoses on the elbow one office is larger than the other and they must be put on the correct one,i switched them around the unit flamed up. and now i have sweet heat again.no code 99.
Dec 17, 2016 | Rinnai Heating & Cooling
I HAVE A JACUZZI HEATER RINNAI 95GS-5 DO THINK PROPANE WOULD WORK ON THIS ITEM
Contact Rinnai, or look at product manual.
Products rated for natural gas do not work with propane.
Propane burns hotter and has more pressure... wrong gas can cause explosion
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 11, 2015 | Rinnai Water Heaters
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Problem is with my Rinnai propane gas heater in my LIVING ROOM, not car. Please see previous question. Thanks.
Turn it off. Check connections and hoses with very soapy water for leaks (it will bubble)
If you can't find it... I would either return it if possible... or go take it to a propane professional for testing.
Dec 20, 2012 | Rinnai Energy Saver Direct Vent Wall...
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinaai LP space heater will not shut off when set temp is reached
Test the thermistor by using an ice cube. Place the cube on the thermistor and see if the unit starts. Then using a warm towel, wrap the thermistor ans see if it stops. Watch the display to see if it is registering the changes in temp. I suspect a bad thermistor.
Jan 02, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Oct 29, 2008 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai energysaver 1004F
Sorry friend!
I think this is it.
www.rinnai.us
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
1,889 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
Craig Butler
Craig Butler
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
