Question about Dryers
Heating element stays on after the drying cycle stops and the timer will also continue on with the door shut or open once you start a drying cycle. I replaced the timer and the start push button.
  • Anonymous Apr 05, 2009
    heating element stays on after door is open and dryer has stopped. I have been unplugging the dryer so I don't cause a fire
  • 3,463 Answers
I would suggest that you check the door switch, as the m/c should not work with the door open,whilst the door switch is made everything will continue to work.
Plz rate my solution.
Thanks.
Posted on Dec 23, 2008
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 | GE Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Sep 27, 2012 | Frigidaire Dryers
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer gets hot but the clothes stay moist and there is dampness on the door when you open it.
Clogged Vent
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 13, 2011 | Dryers
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Dryers Logo
147 people viewed this question
Top Dryers Experts
Marvin
Marvin
