Question about Sewing Machines
I lost my Pfaff 2034 expression manual (am a new to sewing) - and need assistance in grabbing the thread from the bobbin; I am not sure if I have everything set up correctly. Can you help?
I got pfaff expression 2 not stitching i have rethreaded changed needle reloaded bobbin cleaned out all of bobbin area
If the thread is not picking up the bobbin thread and you have installed a new needle, then your machine is not in time. Search for sewing machine timing or take it for service.
Dec 24, 2016 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
I need to know how to wind a bob in for Pfaff 2036 machine. I would also like to obtain a copy of the instruction manual for this machine
How about this?
Threading Pfaff Sewing Machine mov
PFAFF expression 2034 Instruction Manual
(this is for a 2034 but is probably close enough to your machine to be useful. Usually, there is a very slight different between models, that most often just entails a few extra features or decorative stitches.)
Nov 03, 2016 | PfaFF Sewing Machines
My Pfaff Expression 2034 sewing machine is suddenly making an almighty mangled mess at the bottom - it doesn't matter how I re-set the tensions. What can be the problem?
Be sure to use a brand new needle.
Remove the upper thread and bobbin. Reinstall the bobbin making sure it is turning the correct direction and threaded properly in the bobbin case.
RAISE the presser foot and rethread the top thread. Confirm the thread pathway is correct.
Most often, knots (thread nests) occur under the fabric because the machine is misthreaded or the thread is not seated completely in the tension disk.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Sep 22, 2016 | PfaFF Sewing Machines
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
174 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
