Question about GE 15" Laundry Pedestal for Horizontal Axis Washers and Dryers - White-on-White
GE: dishwasher isn't draining water and leaks foam during cycle
Model: gsd2000j01ww
I've opened the panel underneath, i don't see a sensor.  I've checked the plastic drain and nothing is blocking it.  I can't unscrew the plastic drain because there's a layer of foam from the wash and i can't see it.
The water just stays there and doesn't drain.  This has happened to me in the past, i switched powders and the problem was temporarily solved and it drained fine, but i guess i put in too much powder this time (with the same powder!) and for some reason it's over flowing again.
This leads me to believe its not the powder, but something else sinister is happening behind the scenes.  I've been bucketing water out of the bottom as much as i could...   i hope someone has an easy solution.  Maybe there's a switch or simple sensor that isn't being triggered?
  • Ferdzilao Dec 29, 2008
    I have the same problem. Awhile ago, I tried to remove the gasket in the drain. So far it drained the water and I am thinking of totall removing it but not quite sure if it is required.
  • Anonymous Apr 12, 2009
    where is the gasket inthe darin- same problem here,
    thanks
    Scholar:
  • 55 Answers
Drain hose could be plugged.
Posted on Aug 17, 2009
Samsung dishwasher leaking from bottom
Whenever this happens to me, there is food/debris covering the plastic mesh screen that covers where the water exits underneath. It starts dripping because, with it clogged/impaired, the water inside rises slightly and starts leaking out of the bottom front door seal. After I clean up the debis (and sometimes there is debris near/in the drain itself - that's why the mesh pops off so that you can get to it), the leaking stops. I also put a new foam seal on the bottom of the door (just added self-sticking insulating foam strip like you would use on a front door of a house, right on top of the lame seal that was already there), worked great. Good luck.
Jan 25, 2018 | Samsung Dishwashers
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
GE PDW9280J00SS not draining. I have read other posts that say this is a "water level sensor problem" but that doesnt make sense since it FILLS to the proper level. After cleaning cycle, then it...
GE dishwashers use either a drain solenoid or a separate drain pump assembly. Sounds like your drain pump isn't getting power to it until you start other cycles, which sounds like control board issues.
Sep 25, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
GE GSD2000J01WW dishwasher , full of water at bottom of machine
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 22, 2010 | Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Jun 11, 2006 | Hotpoint 24 in. FDW60 Free-standing...
GE 15" Laundry Pedestal for  Horizontal Axis Washers and Dryers - White-on-White Logo
388 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
