Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
How do I extend the number of rings before Brother switches to fax?
Our phone/fax only rings four times before it cuts over to fax reception. So we really have to rush to catch our calls. Scotty07
    Problem Solver:
  • 20 Answers
Press fuction key and select ring setting, change to 1 - 4 rings.
Posted on May 01, 2007
My phone and fax machine are on the same phone line, but with different numbers. So when it is on F/T setting, when our phone rings, the fax picks up and starts beeping (not screaming) on the 4th ring -...
Two different numbers on the same line means you're paying for "distinctive ring" service. One pattern of ringing for one number and another pattern for the other number. Your fax's owner's manual has the instructions for training the machine to answer on the correct pattern. If the book has disappeared, download it from here:
http://www.brother-usa.com/manuals/default.aspx?PGID=2&R3ModelID=PPF770&ModelID=455#.UAb2zVLQfaI
Nov 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
My fax machine answers my phone calls
you have a crossed phone line in the wirering coming out of the phone jack at the wall
Dec 23, 2008 | Brother IntelliFax-2820 Laser Fax
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother MFC-210c printer
Check the basic settings for your printer to see if they offer 'manual' pickup of the line instead of only the number of rings. I've had the same problem years ago and had to set the fax machine for 6 rings, answering machine for 4 to allow me time to pick up the phone in case I was present. You should be able to find complementary settings with your two devices.
Sep 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
No fax reception
Send will work on any phone lines
fax machines are often set to only answer 'secondary' ring tones, double triple or higher. When the line was repaired the phone company may have dropped the special tone off your secondary fax line number, fax will not answer without that tone.
Check in the fax answer settings, what the ring tone is, specific instruction on menu settings in your user guide,
Ring your fax line, and check the tone.
If single number fax/phone, check that the fax is set to asnwer all calls then pass on non faxes
Jul 11, 2008 | Brother IntelliFax-2820 Laser Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Intellifax 2820
It could be a compatibility issues between the two faxes. If the other fax is particularly old its communication speed could be too slow for your fax.
Also don't rule out the line on there end. Many times in my job I've had Telephone company's check the line remotely and say its ok but its not until they come out to site that they find an actual fault.
Do a manual reception. Put your fax reception mode from automatic to manual. When the fax rings in pick up the line with the hook or speaker phone button and then press the start button. This rules out a fair part of the line correction. If you can receive of course.
Feb 06, 2008 | Office Equipment & Supplies
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Brother Fax T86
Try this... 1. Press Menu/Set 2, 1 2. Press <-- or --> to select Ring Delay, then press Menu/Set 3. Press <-- or --> to select how many times the line rings before the machine answers, then press Menu/Set when you see the desired ring number. 4. Press Stop to exit. Hope this helps.
Jun 14, 2007 | Brother FAX 8650P All-In-One Laser Printer
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
