Question about Texas Instruments TI-84 Plus Calculator
I have made a graph on my calculator but i dont know know how to print it
  • Anonymous May 18, 2009
    i have the same problem
  • 24 Answers
Tell us the exact make and model of the calculator and someone may be able to figure out if making a hardcopy is possible.
Posted on Dec 21, 2008
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a...
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Jul 26, 2011 | Casio FX-9750GPlus Calculator
My graphing calculator dont want to graph its says "ERR: INVALID DIM" What can i do?
You're trying to graph a function that does not involve stat plot features, while the calculator is trying to do so. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Feb 03, 2011 | Texas Instruments TI-83 Plus Calculator
Everytime i try to graph it say ERR: INVALID DIM and then below it, it say 1:Quit. i dont know how to fix this and i dont know where to enter the diminsions in. please help me! THANKS!
One of the statistical plots is still active and you must turn it OFF.
  1. Press [2nd][Y=] to open the (STAT PLOT) configuration screen.
  2. Press [4:PlotsOFF]
  3. The PlotsOff Command echoes on main calculator screen.
  4. Press [ENTER] to run command.
  5. Go back to [Y=] editor to edit the functions if necessary, then press [GRAPH].
Dec 17, 2010 | Texas Instruments TI-84 Plus Calculator
We already have this calculator and need to know if it is considered a graphing calculator. Thank you, RH
While it may have many of the same functions as a graphing calculator. It cannot produce a graph on the screen. This is required for most classes. It is not considered a graphing calculator, and you will most likely have to buy a new one.
Aug 23, 2010 | Casio FX-250HC Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
How can I print graphs?
  1. Create your graph on calculator.
  2. Connect the calculator to the computer using one of the two methods: SilverLink Cable of the USB Direct Cable.
  3. On the computer RUN the TIConnect Software.
  4. In main window, find the TIScreenCapture icon (it is afflicted with a Camera and a curve graphed)
  5. Click the TIScreenCapture and
  6. save the image in jpeg or png format (bmp format file are too big)
  7. You will be able to print it from the computer using an image editing software,
  8. or insert it into a word document and then print the document.
Apr 17, 2010 | Texas Instruments TI-84 Plus Calculator
When I go to the y= menu I have \r1= and I dont know how to change that. please help
Your calculator is currently configured to draw polar graphs. To recover the more common Y= graphs,
  1. Press [MODE]
  2. Use down arrow 3 times to get to the line FUNC PAR POL SEQ
  3. Use left arrow to highlight FUNC and press [ENTER]
  4. Press [2nd][QUIT] to exit the MODE screen.
  5. Restart your graphing.
Jan 21, 2010 | Texas Instruments TI-84 Plus Silver...
I dont know how to graph
Turn calculator [ON]. If you do not see the menu icons, press [MENU]. Use the arrow keys to highlight the [GRAPH] icon.
An entry screen appears where you enter the functions you want to graph.
On the first line you have Y1= . After the equal sign enter 2[x] [X, theta,T] + 1. When finished press [F6: Draw] Your graph appears on the screen. If you see the axes, but no graph, press [Shift][V-Window] and press [F3:Std] then [SHIFT][QUIT] will take you back to the screen where you enter the functions to draw. There press [F6:Draw].
Hope it helps.
Sep 21, 2009 | Casio CFX 9850GA Plus Calculator
I have a tI-83 graphing calculator I dont have a manual and dont know how to use the fractions
Hello
OOPS!! The solution has been posted as a clarification report.
Hope it helps
Sep 01, 2009 | Casio FX-115ES Scientific Calculator
Printing off graphs from a calculator
Yes you can transfer everything on you YI92/TI92PLus to your computer.
To connect it you need TIConnect software, and a USB TI Silvercable.
Once the software is installed, you can communicate with your calculator (capture anything on your TI screen as an image to your computer, install applications, transfer programs and so on).
Run TI connect on your calculator.
Draw the graph on your TI 92.
Connect the calculator to the computer.
Click Screen Capture in the TI Connect software window,
It will be store it in your user directory (My Documents ->My TI data)
Hope it helps
Jan 29, 2009 | Texas Instruments TI-92 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
119 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
