Question about Estate TAWS800JQ Top Load Washer
I think it could be the motor brushes
Washing machine will not spin
This happened to me and it was only the button that is on the right side that when you close the lid gets pushed down to far and then it won't spin. shut the lid and see if the button is going down or is down too far.
Posted on Dec 27, 2008
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
Aug 08, 2014 | Beko WME7247W Washing Machine
Asko 10505 Washer will drain but will not spin. Initially that was the problem, but then in trying it out again the washer will fill with water, will drain but will not even wash now. Do you think it is...
You don't mention if the drum spins if you choose the spin program, if it doesn't it could be the brushes on the motor. This would be a cheaper option to try first rather than a board. sometimes you can clean the com or tap the brush carriers gently and get the motor to spin on an empty or small load.
If you're confident, with the power offer and machine isolated you can check the resistance across both the brushes and slowly rotate the motor as a test.
hope this helps
Mar 12, 2013 | Asko Washing Machines
My 1200I washes ok but does not get to spin speed, I suspect its the motor brushes, is this correct?
It seems unlikely as if the motor brushes were worn I would expect problems making the motor turn at all. It would seem that a number of owners have had the same problem and it is due to the load sensor thinking that the load is not even. If it thinks the machine will be subject to excessive vibration it stops the spin progressively. I don't know how the machine checks for uneven load, there must be a vibration sensor, maybe it gets worn and needs replacing, but I suggest you redistribute the load and spin again. Make sure the machine is level and not rocking. Also have a look here http://electrolux.manualsonline.com/washerdryer/ew_1200_i/possible-causes-21.php Please rate my reply thank you.
Jan 05, 2011 | Electrolux EW1200i Front Load Washer /...
Washing machine not washing or spinning
More than likely worn brushes in motor
Remove top cover, and slacken motor bolts holding motor at top right of washer. slide out carbon brush holders in motor, and replace if less than 3 or 4mm long.
This should solve the problem.
Apr 09, 2010 | Hotpoint WM56 Front Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Beko w765s front loader wont spin
Hi if your beko w765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor
Aug 20, 2008 | Washing Machines
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Washer won't spin
A common fault on a front loader washing is brushes wearing out in the motor. A general maintance is to check these brushes out about ever two years. Isolate the washing machine from the power. Remove the motor and with a small screw driver lift the brushes of the commutator or just take it down to your local motor rewinder and get him to bench run the motor and test it while you wait. If its had its day look around for a good second hand one. It could be in the electronics but i have seen a motor take the electronics out?? I think its the motor???
Jan 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
23 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
