Question about Panasonic NN-S951WF Microwave Oven
Microwave, Panasonic model #NN-S951WF will not start. Electrical receptacles working. The fuse connected to the power cable has continuity. This has happened before but only briefly and when the unit operated it worked well. So I am surmising that it may be the door latches but how can I tell?
  • lbenn Dec 25, 2008
    Thanks for your response but I have no display and no light when the door is open. I checked the fuse to the power cord and it has continuity (open). The door latches seem to be okay, took apart and checked the switches and when pressed they have continuity. I need to know where the wiring diagram is so I can check to see if its a circuit board.
  • Panasonic Master
  • 9,098 Answers
If you have a display and the inside light comes on when you open the door, it won't be the fuse.
First, please press and hold the Start pad for about 4 seconds to see if the child lock comes on. (This is detailed in the owner's manual).
If it does, that means the pad on the keypad is okay, and you can press and hold Stop to turn it off.
If it does not, then you may have a bad keypad.
I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You are correct to suspect the door switches, especially if the Start pad is okay.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Or see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 25, 2008
Need to reset but only get demo mode.how do I reset?
please see how to do it. God bless you
Pull the plug for a minute or two to reset it.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2gUPvcOsi
Oct 01, 2013 | Panasonic NN-S951WF Microwave Oven
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
My Panasonic Genius Prestige model microwave is in the "Demo" mode and will not operate. How to fix it?
RESET THE SYSTEM BY UNPLUGING THE MICROWAVE CORD FROM POWER FOR 30 SECONDS, CONNECT BACK TO POWER IF THE MICROWAVE CONTINUE WITH THE PROBLEM MAY HAVE A BAD CONTROL BOARD OR BAD ELECTRONIC CONTROL PAD...
Feb 19, 2011 | Panasonic NN-SD797S Microwave Oven
There is no power coming into my microwave which is a panasonic nn-L531WF model. I think it's the fuse. How can i change the fuse?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Panasonic NN-L531WF Microwave Oven
My new microwave is completely dead
good day,
hope this link below will solve your problem.
kitchen appliances
May 24, 2009 | Panasonic NN-H504WF Microwave Oven
Panasonic NN-S254B How fried is it?
There is an internal fuse, so check that first. If the fuse checks ok, definitely buy a new microwave - losing a neutral usually damages the main circuit board. Given the cost of the board and the distance involved, it just wouldn't pay to chase the parts down
Jun 18, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-S951WF Microwave Oven Logo
299 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
