Question about Power Acoustik LT-980/2 Car Audio Amplifier
Amplifier I own a car that, one of the speakers work loud and the other you can barely hear. One day I was sitting in my car and noticed that the music shifted from the speaker that worked to the speaker that didn't work and now the music is barely heard. It sounds as if it has a lot of treble. Is this the amplifier's fault or the speaker?
  • 113 Answers
Check faulty or old connections esp rca
Posted on Aug 09, 2007
SOURCE:
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
Can barely hear speakers when they are turned all the way up
Assuming this applies to all the speakers in the TrailBlazer, you likely have an amplifier transistor in the radio going bad. When they occasionally work, or you get a "crackling" sound it is usually the amp. A slim possibility is a bad ground, but that usually won't affect all speakers, only one.
Mar 13, 2014 | 2004 Chevrolet TrailBlazer
Volume decreases drasticly when playing fairly loud for 15-20 minutes
You're probably overdriving the amplifier, meaning the speakers are sucking up more power than the amplifier is capable of. When you turn it up loud it overheats and causes the system to go into a protect mode so it doesn't catch on fire (yes... it happens!). Make sure your system is capable of handling the power needs of your speakers. And don't burn your house down! I had a high-end Harmon-Kardon receiver burst into flames. It's a good thing I was standing next to it or my house would have been toast.
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
Mt Audi A6 1999 am radio has a loud squeal.
sound like a speaker wire is grounding out somehow
Jun 03, 2009 | 1999 Audi A6
Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
1.
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Ed
Apr 09, 2009 | Onkyo TX-SR803 Receiver
New behringer powered mixer, comes on, but doesn't hear anything.
Fan comes on with temperature rise. Not a problem if off till you start driving speakers loud.
Make sure standby switch is up. The slide switch is up to A/B.
The main fader iis up. Your input fader(s) are up. The trim controls are up enough. Inputs are plugged to input and not the inserts.
Be careful... this unit has a lot of power and can blow speakers.
Nov 23, 2008 | Behringer POWERED MIXER, 20 CH, 400 WTS...
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Stopped working.. Blown? or..
how did u wire the speaker ?what is the speaker rated at 2 ohm or 4ohm? thees kicker l7s 15 inch is rated for 1000 rms and 2000 peak the only thing that could of hapend was somthing was touching some were in the wiring or u hade the speaker wired at a load of 1 ohm
May 18, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Amp cuts off...
Are the woofers single or dual voice coil?
How many ohms per coil?
If they are dual voice coil, are the coils for each speaker wired in series or parallel?
Are the speakers connected directly to the amp or are the speaker in series (one wire from each speaker connected to the amp?
Have you checked the DC voltage at the amp when you're playing it at high volume (where it cuts off)?
Dec 22, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
51 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
