Question about Lexmark X2600 InkJet Printer
Replace ink cartridge
Bought this printer 2 hrs ago. inst went fine but it tells me replace cart with every print attempt *& its brand new
  • gandlmurphy1 Feb 14, 2009
    hi i refilled black ink cartridge,i have done it before on old lexmark but dont know how to reset ink level on my new x2630 printer, keeps on telling me "black cartridge replacement required" thankyou
  • florys_green Mar 14, 2009
    hi i refilled black and color ink cartridge,
    but dont know how to reset ink level on my new x2650 printer, keeps on
    telling me "black and color cartridge replacement required" thank you
Make sure there is not any small piece of paper, or any foregien matter between ink cartridge and cradle.
Posted on Dec 21, 2008
Printer keeps flashing print cartiagein right not supported..alos comes up on screen stating cartiage on right side is not intended for this printer. I have been using this cart. for awhile now it is the...
There is a problem with the computer sensor in the ink cartridge. That is what is causing this error that you are seeing. Is it a refilled cartridge or did you buy it new from the store? If you bought it new and it is doing this, then take it back to the store and tell them it is a defective cartridge and you want to exchange it for a new one. If it is a refilled cartridge and you bought it from an ink store, take it back to them and tell them that the sensor is failing. They will replace or repair the sensor and then the cartridge should work properly.
Hope this helps?
Nov 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
HP B9180 printer thinks new cartridge is empty
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | HP Photosmart Pro B9180 InkJet Printer
My printer won't print black
Did it print black before you replaced the black cart?
If so try 1. purging the new ink cart. 2. reseat and purge 3. rpl it is defective.
Feb 21, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Replacing ink chip on IP3500
These is the common problem when you buy new cartridges which have kept over long time in the shelf ..If these are new cart and original please contact the company and get it replaced as the new cart comes 6 months warranty.........................
Jun 06, 2008 | Canon PIXMA MP530 All-In-One InkJet...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Lexmark X2600 InkJet Printer Logo
505 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
