Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Reassembly of Auger Housing
I had chewed up some spacers and an oil seal on my MTD Snow Thrower Auger assembly. Removing the assembly from the shaft was fairly easy because the spacer was chewed up and I could pull the housing apart and around the gear drive. However, with all the spacers reinstalled, there is no way to slide it back on the shaft. What is the best and most simple way to remove the shaft in order to reassemble the auger housing.
    Scholar:
  • 76 Answers
If you go to www.mtdcanada.com you should be able to find aparts breakdown for your machine which will be helpfull in puting it back together.You will need your model and serial # to find your parts breakdown. The breaedown wont tell you how to do it but it will give you a good idea. if it's not helpful the if you post the model and serial # here then I can see what you will need to do.
Posted on Jan 07, 2009
Was wondering if anyone would know the age of this snowblower and hp output, its for sale and before I buy I would like more info about it. It says Snow Champ 5/24 power propelled
Looks like the UP605/8461 was made for Aircap by MTD for just 1 year (1989)... the equivalent MTD model number was: 319-550-002
Here are some links to sources for available parts along with obsolete replacement/aftermarket recommendations:
MTD UP605 8461 319 550 002 Snow Champ Self Propelled Snow Thrower 1989...
MTD 319 550 002 UP605 8461 1989 Parts Parts Diagrams
The parts that go bad the most often are the wear skids on the outside of the auger housing, and the shave plate along the bottom edge of the auger housing.
Carburetors tend to gel up from the 15% ethanol the farm lobby got congress to put in all our gasoline, but that's not really 'going bad' - often you can actually clean the 'varnish' out of the orifices and passages with aerosol carb cleaner... shops would have a heated (about 105F) ultrasonic parts cleaner, but it's usually cheaper for DIY'ers to buy a new carb.
Mar 08, 2015 | Garden
How do I remove the impeller from a 800 Gilson snow thrower
you have to remove the chute, then the auger bearings and any gearbox stabilizers. remove belt now turn auger while watching through chute hole until you see roll pins through your shaft. knock these pins through ( usually 2) then you can remove the whole auger assembly which reveals your impeller
Nov 01, 2014 | Garden
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
After engine has been started the auger will not turn and starts smelling of burning rubber
something like ice in bottom of blower housing keeping it from turning
and belt is burning up
Feb 06, 2014 | Mtd 2 Satge Snow Thrower 26"
Auger will not engage
blocked or frozen blower inside of housing, move to warm area or chip out the ice
youre going to need a new belt after burning that one up
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
This is probably something simple. I have an MTD
I am going to guess that there is a flat spot or hole that the machine screw (or set screw, I presume) should be either against or tighten into. When you tighten it against the round portion of the shaft it will allow the auger to slip and the screw to come loose. Check and see if that isn't the case.
Feb 16, 2010 | Mtd Garden
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
135 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
