Question about Frigidaire FEF336BC Electric Kitchen Range
Looking for fuses in my range
Ive never seen a range without fuses can anyone tall me if there are any or where to find them
  • 121 Answers
No fuses on range.
Posted on Feb 16, 2009
Check control board
yes you will have to remove the top
Feb 01, 2016 | KitchenAid KDRP467KSS Dual Fuel (Electric...
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
Jul 09, 2014 | Health & Beauty
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 | Ovens
Does anyone know which fuse is for the instrument panel? Anyone else seen this problem?
The fuse for the instrument panel is the one under the hood.It is a 10 amp fuse.Just look under the cover of the fuse panel and it will have a list of the fuses.This fuse is for the i.p.panel and the drivers info center.As for your second question.No I can`t say that I have seen this problem.Hope this helps.Good luck.
Feb 23, 2012 | 2005 Hummer H2
How many fuse box do a 2006 range rover sport have and where are them
hey guys really need major help...2006 range rover sport hse radio audio keeps on coming on and off..ive checked and tested fuse and still no luck ...what did i miss ? is there something else i need to look?
Nov 29, 2011 | 2006 Land Rover Range Rover Sport
What is the correct way to use a tasco 5x20mm
If you are referring to the Tasco 5x20mm Golf range finding scope, Then you look through the scope and view the hole with a flag in it. Place the hole at the baseline as seen through the reticle, then read the numbers off the line at the top of the flag. I believe these are in tens of yards, not meters. So: 15 through the scope would actually be 150 yards. Finding the range to objects other-than the hole flag might be possible if you could accurately estimate how tall a hole flag would appear at the location you are looking at.
5x magnification is enough that it might help to stand with feet slightly apart and hold the scope with both hands to help steady the image. I can see the image wiggle with my shaky hands and heart beat.
I'm sorry that I can't help select the best iron or driver for each range. That will be up to you or a good caddy.
I hope this helps some.
Good luck,
Bentley
Mar 26, 2011 | Sport & Outdoor - Others
RHEEM 50 GAL ELEC TALL Water Heater 6YR SC 83VR522: I just purchased a home with this water heater and...
The two most common problems Ive seen that fit this description are, incorrect voltage going to the water heater or the fill tube on the inlet side of the unit has broken off in the tank. The voltage problem can be checked with a tester. Ive seen breakers go bad and cause this. The fill tube can be checked by removing the cold water connection at the tank and feeling to see if the tube is still hanging there. Hope this helps.
May 17, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
WHAT CAUSES THE F1 LIGHT TO FLASH DURING BAKING?
most commom problem for f1 is the tempreture sensor in oven, however also ive seen alot of clocks needs to be replaced for f1. without testing sensor im not sure witch one.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Looking for prop spline size for stainless prop Yamaha 150 VMax
almost all splines should fit on that vmax, Ive owned one and used a few different props for different applications
Apr 12, 2009 | Boating
AIR SUSPENSION INOPERATIVE WARNING INDICATOR ON IN 2004 RANGE ROV
I have never heard of strutmaster, but the air to coil kits that ive seen have been done by a group called british atlantic. They are Land Rover nuts that do this and have the resources to shut the light off, check out there website these guys are the best
ps dealerships cant do conversions because the manufacturer doesnt allow it.
Apr 03, 2009 | 2004 Land Rover Range Rover
Frigidaire FEF336BC Electric Kitchen Range Logo
719 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
