Question about Denon Audio Players & Recorders
Denon receiver is blinking in standby mode -
My receiver is blinking in standby - when you hit the on off button it comes on but then reverts to stand by - what do I do?
simplemitch
  • 752 Answers
SOURCE: Denon AVR-4800 5.1Channel Standby light blinking
It's going into protect. Unhook ALL the speakers and see if it still shuts itself off. If so, then it will have to be taken in for service.
Posted on Oct 27, 2007
  • 6 Answers
SOURCE: Denon AVR-1508
sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Posted on Jan 13, 2008
SOURCE: Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Posted on Oct 16, 2008
SOURCE: Power/Standby mode blinking, what is the reason?
I have a Denon AVR1708 and a Denon AVR687. Both had this issue and the issue is related to high temperature usage; like if the unit is in an entertainment systems with poor ventilation. I was able to fix both fairly easily. The issue is related to the voltage regulators on the power supply board on the 1708 and the main board on the 687. In my case, I had failures of the -15 volt regulator KIA7915PI. Both I believe were related to high temperatures.
You can get the regulator for as little as 50 cents at some online stores. The job on the 1708 was easy, however, on the 687 it was a bear. It took about 1/2 hour on the 1708 and 2 to 2 1/2 hours on the 687. The component is a lot harder to get to on the 687. The component needs to be unsoldered and removed and the new component soldered in. You will probably have to remove some caps to get go access. Thermal grease should also be applied to the new component.
Posted on Aug 30, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
How to reset denon s 301receiver?
Instructions
  1. How to Reset Denon Receivers
    • 1 Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
    • 2 Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
    • 3 Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
    • 4 The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Sep 09, 2014 | Toshiba DVR40 Multi System DVD Recorder...
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
ITS ON STANDBY MODE & NOT ABLE TO GET ITS DISPLAY
Try this, not sure if the same would work for ya.
Swich off the amplifier.
Prior to the process check the wires connecting the speakers are not creating a short circuit which is apparently putting the amplified into a standy mode.
1. Press the "A" "B" and power key all at the same time and hold on to it.
2. The amp will go into a reset mode and will keep blinking till it gives a normal "click" sound and the amp turns on.
3. this process would take about 2 - 3 minutes.
4. You may then release the buttons.
5. If it goes into a standby mode again and does not power on, or the standby keeps blinking, get assistance from the engineer.
6. Once it is on, you shall need to do the resetting of alll the configurations done earlier.
Hope it works, it costed me 3k to get the job done.
Nov 12, 2009 | Denon AVR-1603 Receiver
My Denon AVR-1507 keeps automatically turning off every time I turn it on. Then the standby button blinks red. Is there a quick fix to reset the microprocessor?
Hi
Thanks for using FixYa. Store these instructions in a safe place. After reading, store these instructions along with the warranty card in a safe place. Whenever the power operation button is in the STANDBY state, the unit is still connected to AC line voltage. Please be sure to turn off the power operation button or unplug the cord when you leave home for, say, a vacation. Note that the illustrations in these instructions may differ from the actual unit for explanation purposes. Please click on this link for further reference---
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Denon Audio Players & Recorders
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Jun 27, 2008 | Denon AVR-1705 Receiver
Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
May 24, 2008 | Denon AVR-1603 Receiver
Standy light blinking
caro colega,ate agora nao conseguir resolver,este problema ,pois ja troquei todas as potencias de saidas e ate agora,nao sai do stand by
May 13, 2008 | Denon AVR-1601 Receiver
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
306 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
