Question about Ubi Soft Entertainment Buck Bumble for Nintendo 64
I cant go move nothing at the menu of buck bumble rom (project64)
On the menu of buck bumble I cant go to another option for example training. I can only so one player only and thats it. please help. Also i am using a emulator-project 64 1.6
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
TRY AN OLDER EMULATOR IF STILL DOING IT GET THE NEWEST
Posted on Jul 06, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
The train gets no power.
The instructions are sometimes a bit vague: for example, once switched on the train needs to sit and charge before it runs, but that is not very evident from the instructions and many folks spent some frustrating minutes wondering why the train wouldn't move.
Jan 03, 2014 | Lionel The Polar Express Train Set
I got a NES (finally) but i got a problem. when i start it up with (for example) zelda i can select a save, in other words when I push the up or the down button it does nothing. But when i press start to...
The reason it doesn't work in the menu is because it doesn't use the D-pad (the plus-shaped button that you use to move around). To go through the menu options, you need to press the Select button (that's the left of the two small buttons in the center of the controller). Many games use that to select menu options instead of the D-pad.
Jul 06, 2011 | Nintendo NES Console
Trying to install on windows 7
um, more information would be nice.... im assuming you are trying to install the OS its self?
1) when you boot, go to your bios options (usually f8 or f12, it says when you turn your computer on)
2) go to the boot order menu and move the CD-rom/ DVD-rom drive to boot before the hard drive (sometimes denoted as hdd)
3) place the cd in and reboot your system (after saving the changes!)
note: some motherboards have the boot menu as an option (usually f2, but it depends on the mother board manufacturer). if you see that, you can pick that option instead of the bios menu, and it will give you the choice to boot from your cd drive!
May 08, 2011 | Computers & Internet
Can't change it from dutch to english
try other country code maybe this one help you see following:
for example HT752GB02164 will give you a English-WWE or Arabic rom.
for example HT751GB06969 will give you a English-WWE or Arabic rom.
for example HT751GB10969 will give you a English-WWE or Arabic rom.
for example HT751GB07164 will give you a English-WWE or Arabic rom.
for example HT751GB10164 will give you a English-WWE or Arabic rom.
for example HT750GB02164 will give you a English WWE rom.
for example HT736GB05969 will give you a English WWE rom.
for example HT736GB03969 will give you a English WWE rom.
for example HT738GB06164 will give you a English WWE rom.
for example HT751GB16969 will give you a English WWE rom.
for example HT751GB17969 will give you a English WWE rom.
for example HT751GB18969 will give you a English WWE rom.
for example HT751GB19969 will give you a English WWE rom.
for example HT751GB17164 will give you a English WWE rom.
for example HT751GB18164 will give you a English WWE rom.
for example HT736GB02164 will give you a Russian rom.
for example HT736GB01969 will give you a Russian rom.
for example HT736GB00969 will give you a Russian rom.
for example HT738GB02164 will give you a Finnish rom.
for example HT736GB20969 will give you a French rom.
for example HT736GB08969 will give you a French rom.
for example HT736GB04969 will give you a French rom.
for example HT736GB02969 will give you a French rom.
for example HT736GB13969 will give you a French rom.
for example HT750GB17164 will give you a French rom.
for example HT738GB26164 will give you a French rom.
for example HT738GB27164 will give you a French rom.
for example HT738GB28164 will give you a French rom.
for example HT752GB24164 will give you a French rom.
for example HT736GB22969 will give you a Spanish rom.
for example HT736GB16969 will give you a Spanish rom.
for example HT752GB20164 will give you a Spanish rom.
for example HT750GB08164 will give you a Italien rom
for example HT750GB09164 will give you a Italien rom
for example HT750GB11164 will give you a Italien rom
for example HT750GB13164 will give you a Italien rom
for example HT736GB23969 will give you a Italien rom
for example HT736GB12969 will give you a Italien rom.
for example HT750GB16164 will give you a Italien rom.
for example HT752GB03164 will give you a Italien rom.
for example HT752GB04164 will give you a Italien rom.
for example HT752GB05164 will give you a Italien rom.
for example HT752GB09164 will give you a Italien rom.
for example HT736GB09969 will give you a Dutch rom.
for example HT736GB11969 will give you a Dutch rom.
for example HT736GB17969 will give you a Dutch rom.
for example HT751GB03969 will give you a Dutch rom.
for example HT751GB03164 will give you a Dutch rom.
for example HT751GB04164 will give you a Dutch rom.
for example HT751GB03165 will give you a Dutch rom.
for example HT751GB04165 will give you a Dutch rom.
for example HT738GB25164 will give you a German rom.
for example HT738GB30164 will give you a German rom.
for example HT738GB31164 will give you a German rom.
for example HT750GB14164 will give you a Portuguese rom.
for example HT738GB04164 will give you a Swedish rom.
Feb 14, 2011 | HTC TyTN Smartphone
HOW CAN I ORDER TRAIN PARTS
You can order parts direct from Kadee's web site:
http://www.kadee.com/link.htm
Jan 31, 2010 | Kadee Ho Trains D&rg Bumble Bee Train Set
No option for my emerson tv menu
okay here is a soluton for the remote www.remotes.com since you did not have to pay me you can use the money there there under$20 bucks and there orginal factory remotes otherwise you need a good unviersal remote.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Emerson EWF2703 27" TV
Factory reset
to factory reset a laptop you will have too hold some F keys(for example F8), it says how in the manual that came with the pc
Dec 16, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Menu steup
go to main menu>options>orgnaize main menu>then select which type of setup u want................else select each option u want and move it acc to ur wish.
Sep 04, 2007 | Nokia 6102 Cellular Phone
Ubi Soft Entertainment Buck Bumble for Nintendo 64 Logo
328 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
Keith Koene
boro_mk5
boro_mk5
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
