The Tv just got a green ring around the edge of the picture
We moved the sony tv which is about 5 years old up stairs and now it has a green ring of color around the screen. Can I fix that. Its not that old,
  • 24 Answers
If this is a TV with a CRT (glass tube screen) then this pattern will be caused by a residual magnetic field in the shadow mask (the metal bit at the front behind the glass). Normally when a TV is turned on from cold a set of wire coils demagnetize (or degauss) the set and clear these patterns. If this circuit is not working you will have to take it to a repairman and get him to do it manually (or the shadow mask in twisted). In future handle the set with care and keep it away from strong magnetic fields (vacuum cleaner motors, etc).
Posted on Dec 21, 2008
Our Trinitron KV-36XBR400 powers up then no picture
How old is this tv?More than 5 years old.Not worth it to repair CRT tv at this prices.Tries unplug,replug an hour later,might help,see if reset itself.U can buy a pretty good 32" LCD tv at $400 or less these day.It not heavy as the CRT tv,it alot easier to move the tv around the house or other locations.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I bought a 3 year old Sony FD Trinitron WEGA KV SW29M50 29 and it did not come with a manual question thereare 5 jacks above the video jacks what are they for i have surround sound speakers how do...
The inputs you refer to should be colored as follows.
Red
Blue
Green
Red
White
(not necessarily in this order)
These are what are called Component Video inputs and is one of the way that HD capable equipment connect to your television. It will not get true HD picture but this input will provide you with a crisper clearer picture.
Good Luck and Happy New Year.....
Jan 03, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
There is a discoloration on the sides of the tv. there is like a color of purple and green and makes the picture blurr looking- Guest
This is most likely because you have an unguarded speaker too close to the T.V. If you have a speaker close to the television, try moving it around a little to see if the discoloration goes away. If that doesn't work, you can try moving a large magnet around the edge of the screen to move the CRT guns back into place. Best of luck.
Aug 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
