Question about Acer TravelMate 4000LCi Notebook
Bios Boot Block Recovery
I flashed my bios and after restarting it's already black out. Is there a way to recover it?
  • Prem Chugani Apr 06, 2007
    Thanks for your reply, but after trying google and a generic miniPCI bios that I bought from China, I managed to fully recover my Laptop. Contacting Acer is as good as Throwing your laptop for good. I know cause I'm a professinal laptop repair tech in KSA and acer always recommends replace board in this kind of problem.
    President:
  • 2,961 Answers
Unfortunately not unless, you have a dual bios where the old settings are saved, flashing the bios is very dodgy, unless it is absolutely neccasary. You may be better getting in touch with acer to se if the laptop can be reset.
Posted on Apr 06, 2007
In recovery mode and lost power, then battery went dead. Now turn laptop on get the ASUS logo , in center, and Intel Logo, lower right corner, on black screen. Then black screen comes on again with...
Take disk out. Power down. Restart. See if will start up without a disk in it. Might be confused by your disk. Did you try to F8 or F9 while restarting to get into BIOS (trying to remember which one will boot you to BIOS). Then see if the CD/DVD was disable for boot up. Turn that back on if you can get into BOS so it will boot up you recovery disk.. If your OS is completely gone, you will have to reinstall...
Sep 24, 2013 | ASUS K Computers & Internet
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hi i need a expert to resolve my laptop Acer Aspire 1640z . I was upgrading my bios from 3a19 to 3A24 and now... after powering on, i hear 1 long beep and 2 short beeps and my screen is black. Nothing...
According to my troubleshooting manual of Acer Aspire 4520-Z3 about
BIOS Flash Utility:
The BIOS flash memory update is required for the following conditions:
New versions of system programs
New features or options
Restore a BIOS when it becomes corrupted.
Use the Phlash utility to update the system BIOS flash ROM.
NOTE:
If you do not have a crisis recovery diskette at hand, then you should
create a Crisis Recovery Diskette before you use the Phlash utility.
Do not install memory-related drivers (XMS, EMS, DPMI) when you use the Phlash.
Please use the AC adaptor power supply when you run the Phlash utility.
If the battery pack does not contain enough power to finish BIOS flash,
you may not boot the system because the BIOS is not completely loaded.
Follow the steps below to run the Phlash.
1. Prepare a bootable diskette.
2. Copy the flash utilities to the bootable diskette.
3. Then boot the system from the bootable diskette.
The flash utility has auto-execution function.
You need to prepare a bootable Flashdisk into dos mode
then you should search for the above mentioned crisis recovery
diskett and transfer its content to the flashdisk.
I read from another forum that for recovery of Aspire 4520 problem
can be done through pressing of the keys combination as follows:
press FN + ESC and hold them, then just hit the power on button
and release it, after awhile "the power button" should blink red,
release the keys FN+ESC and don't touch anything.
After successful of recover the bios it should restart normally.
That happen after 20-30 minutes. If it doesn't restart just repeat the
process.
Hope it helps
Mar 09, 2011 | Computers & Internet
Monitor went flashing. Won't boot. Says missing
You need to repair your windows system files.
for that insert windows disk or recovery disk into cd /dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then you can see bios configuration page then go to boot menu and set first boot device as cd/dvd rom then save settings and exit from bios .
then it boot with disk follow the procedure on screen then first choose recovery console then type in console "chkdsk /r" it fix and recovers error on harddrive.
Then restart computer then again boot and this time choose R for "Repair previous windows" then it repair it then you can use your windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 02, 2010 | E-Machines W3107 (RBW3107) PC Desktop
I was flashing the bios and it was keeping long so i unplug the power and it never came on again
unfortunately, if the BIOS lost its firmware you must send it to the vendor to replace the BIOS chip
Feb 19, 2010 | Dell Inspiron 8500 Notebook
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
"bootlock" When I turn the computer I get a message
The Boot Block
The preceding section discusses updating the program code in the system BIOS by flashing it (replacing it under software control). If the flash procedure is done improperly, the BIOS code can become corrupted, which will cause the system to go into an unbootable state. Many newer systems come with a feature where a 4 KB "boot block" program is included as part of the BIOS. This is a tiny piece of code whose job it is to recover from a situation where the BIOS code is incorrect or corrupted.
If your motherboard supports this feature, when the PC tries to boot and finds the BIOS code corrupted, the boot block will try to recover the BIOS code, usually by reading it from a specially-prepared floppy disk. You may have to change a jumper on the motherboard to enable this capability, and you may need to make use of a "plain vanilla" ISA video card. The boot block will load the BIOS code and then when you next reboot, the regular BIOS code should be in place and the problem resolved.
You will need to follow the special recovery procedure outlined by your motherboard manufacturer if you want to take advantage of this feature.
Nov 26, 2009 | HP Computers>Laptops HP Nw9440 PC Notebook
Foxconn 45cmx mainboard does not have any BIOS Update Enable/Disable jumper. When the CMOS RAM setting (BIOS Setup) Super Block Protect is disabled and a DOS based flash BIOS upgrade is attempted, the...
It depends on what bios the machine has, there are recovery procedures, atleast on laptop bioses. That when a set of keys is pressed it reads the bios image from a floppy or from a usb stick / cd and flashes the bios automatically.
Look online for Bios recovery (find out what bios you have, ami, phoenix, etc and then look for _____ bios recovery)
Oct 20, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Emachines notebook m5310 corrupted bios recovery
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Reboot the system
Turn the system off
Oct 14, 2009 | Computers & Internet
How can i recover the bios
Flash Recovery-Config Some motherboard makers incorporate a flash recovery-config jumper or boot block recovery jumper on their motherboards. This can often be used to recover from a bad or failed flash. On most machines a small segment of the flash ROM does not get overwritten when you perform a normal flash update. This small portion of code contains a basic boot block which can enable the machine to reload another BIOS from floppy disk.
If you have a laptop or desktop without a floppy. You can either fit a floppy in the conventional manner or in some cases a USB floppy or CD-ROM can be used.
Aug 06, 2009 | HP Pavilion dv4000 Notebook
Acer TravelMate 4000LCi Notebook Logo
451 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
