Can't find codes for Sony DAV-HDX274 HOME THEATRE
I have JVC TV, I would like to control my tv with the home theatre remote. Thanks
  • efraine818 Dec 22, 2008
    Can someone help Please!!
  • Anonymous Dec 26, 2008
    Need DAV-HDX274 SONY HOME THEATRE CODES
  • 6 Answers
SOURCE: Remote code for Sony Home Theater
Try 0035, 0032, 0000, 0636 and 1232
If that does not work try searching for codes:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for.
Posted on Oct 29, 2007
SOURCE: Remote code for Sony Homethetre on LG Remote
Hi
I have a bell satellite PVR system. The techs that have set up this unit, has programmed the remote unit that came with the PVR to work with the Sony mode (KDF42WE655). Recently I’ve encounter a problem and I am not sure how to correct. The problem is I always have a video label 7 on my TV screen and I cant seem to remove I have tried rebooting the PVR unit, also tried to reprogram the remote control. Can you help me to remove this video label off the TV screen?
Thanks in advance …
Posted on Dec 30, 2007
minteker
  • 52 Answers
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
Posted on Mar 19, 2008
marsrover
  • 682 Answers
SOURCE: CONNECTING SKY+
http://www.superfi.co.uk/extras/Sony/davdz230-manual.pdf
Posted on Apr 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: Giant Omnitech remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
I have lost my tv remot
Kamlesh, you can purchase a universal remote for your TV just about any where, even the buck store. Read packaging to see if compatible with your make. See links for remotes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remote Controls
universal remote
http://www.walmart.ca/en/electronics/tv-home-theatre/home-theatre-accessories/remote-controls/N-1548
TV Remote Controls
Mar 05, 2016 | Televison & Video
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
How do I attach sony w60b to sonny DAV-HDZ 284 DVD Home Theatre System?
You can use the Component Video, composite video or HDMI connections to connect the DVD home theatre system to the TV.
See the manuals on this site.
DVD Home Theater System
Sep 15, 2014 | Sony BRAVIA Televison & Video
Remote not working
i want to buy a remote control for sony dvd home theatre system dav-fxg9k, where i can get it?
Jan 11, 2014 | Sony SS-FXG9K Multi-System Region Free DVD...
Universal remote codes
03921,03967,03919,03909. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 08, 2013 | Televison & Video
Cant find a english manual for the sony dav-f300 home theatre system
did you find it?
I need the DAV-F300 manual in English or Hebrew. My problem is that I connect the Sony home theatre system to my Philips TV with HDMI cable and the sound doesn't work
thanks
ran
Mar 28, 2011 | Televison & Video
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
Hi I have the Sony DAV-HDX285 home theatre system and I'm trying to get it to work with my Vizio 47" HD tv. I go thru the speaker setup with the dvd supplied and all speakers are working tthu the home...
I assume you mean the TV sound only comes out of the TV. THAT would involve internal audio controls at the TV.
Why don't you just connect the TV-related audio directly from each source to the DAV instead of through the TV, which adds NOTHING to the sound quality and may even degrade or limit it.
Aug 17, 2010 | Sony Bravia DAVHDX285 Theater System
Televison & Video Logo
446 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
