Question about Nikon 8-25x25 Eagleview Zoom Binoculars Black 7496
Zoom lever stuck
Nikon Eagleview Zoom 8-24x25 CF binoculars...zoom lever is stuck in the 24x position...mild persuasion doesn't budge it
  • 4 more comments
  • pcrobin Dec 21, 2008
    Tried tapping sides to see if that would dislodge whatever is keeping the zoom lever from moving. No dice. Binoculars are fairly new and have seen light use. Not subjected to outdoor use. No dirt or sand. Stored in case.
    Huh? Battery? Motor? These are binoculars!
  • pcrobin Dec 22, 2008
    Nikon Eagleview binos. I haven't attempted disassembly to fix the stuck zoom lever. Without a diagram of the internals or special tools I hesitate to do something that would make the situation worse. I took the suggestion given (tap side & listen for loose parts). Can't see or hear anything out of place. Lever is stuck solid. Could it have overridden the stop? In other words is it now wedged behind the stop?
    Nikon Eagleview binos. Usin a very thin but solid tool to dislodge the thing stopping the zoom lever operation is a good idea but not possible. Angle of attack and close tolerances don't allow that without damage.
  • pcrobin Dec 24, 2008
    The only hope of access appears to be 2 tiny phillips head screws between the lens. It appears that they might hold the focusing ring and zoom lever cover in place. Just a guess.
    I'll be damned. The quarter was just the right tool. Thanks!
  • 4,806 Answers
Hi there
sounds like the lever has got jammed or has overridden its stop point, either way the only wat to deal with the issue is to either spray the lever with WD-40 and see if it will release so you can zoom in and out, or take the binoculars apart with precision screwdrivers, be very carefull if you have to take it apart as it can be sometimes hard to get them back together
kind regards
Posted on Dec 22, 2008
    Guru:
  • 449 Answers
Used a quarter to move the button. happy holiday
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would seem that this lever/knob is actually a mechanical linkage that moves the objective lens. Might the problem be not with the knob but the the objective lens is/are stuck? This would be caused by resting the binoculars standing up instead of flatdown often. Perhaps the "mild persuasion...tapping sides...dislodge" should not be directed to the knob/lever but to the objective lens themselves.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 916 Answers
As your tapping the sides try sticking something solid but thin in to dislodge whatever is blocking do not push to hard so you do not break anything. Then reset it by turning it off for 30 minutes.
Posted on Dec 21, 2008
  • 1,800 Answers
Reset the it by switching it off 30 mins.
    Genius:
  • 1,142 Answers
Try to reset the power take the battery out leave it turned off for 10 mins then try with the battery that should move the motor or you can tap the unit lightly
    Sergeant:
    Novelist:
  • 327 Answers
Just tap the sides slowly as something is blocking the lever to come out properly.and also check out if something is broken or moved from its position
Why do pictures taken have a black, curved area in top corners of image unless I zoom in?
That's because the shutter is damaged and needs repair, You are seeing it in your photos when using the wide end of the Zoom.
May 10, 2014 | Nikon Coolpix P90 24x Optical Zoom Digital...
Nikon lens 55-200mm zoom ring stuck
Try canned air to blow it out. Try holding some mild compression front to back and see if it will break lose. Otherwise, it will have to go to a lens repair shop. I use KEH photo in GA. They have always be honest and reliable, and faster and cheaper than Nikon.
Apr 15, 2014 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Zoom lever gets stuck
Very slight lubricating spray should suffice ..... but see to it that its very little .....
Oct 30, 2012 | FUJIFILM FinePix F200EXR Digital Camera
How can I safely remove corroded and swollen batteries from a set of Sears Discoverrer Zoom binoculars? They sat in a gun cabinet for years and the AA batteries are swollen and will not budge. The binocs...
If they cannot be pushed out from the other side getting them out will be a bear since they are lodged in there. Using small screw drivers you can wedge them in the area between the battery casing and container. The crud has to be loosed for you to even have a chance of removal. Will be one royal PIA and messy. Afterwards you have to get in there and thoroughly clean all yuck with particular attention to the terminals that conducted battery current. Happened to me with my of my favorite torches and ...............GOOD LUCK!
Sep 03, 2017 | Optics
The zoom lever is not working moves but doesnt change
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Feb 20, 2010 | Minolta Classic II Binocular
Value of the model 172 Jason Binoculars
I'm sorry to say this. Not much. Maybe 30 dollars US on a good day on the auction site if the binoculars are in great condition. Zoom binoculars are not known for their quality optics. Jason binoculars have a small collectable quality in a niche market for old Japanese optics. Just to have not for their optics. Non zoom older Jasons are worth a small amount more.
Aug 23, 2009 | Nikon Superior E Binocular
Two rubber eye pieces for Tasco 6x.18x35 triple zoom binoculars
Link
Your binocular might be needing some repair or material replacement. Kindly refer to above link to contact Support Team of Nikon
Thank you.
Jun 01, 2009 | Nikon Action Binoculars
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Nikon 8-25x25 Eagleview Zoom Binoculars Black 7496 Logo
130 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
