Question about Honeywell Programmable Thermostat Heater
HONEYWELL T-STAT I REMOVED A HONEYWELL T-STAT TO REPLACE IT WITH A DIGITAL T-STAT BUT IT WAS DEFFECTED SO I PUT THE OLD ONE BACK ON AN NOW WHEN IT RUNS IN THE HEAT MODE IT NEVER SHUT OFF. IM WONDERING DID I CROSS WIRES OR WHAT
  • 1 more comment
  • JEWEL JACKSON Dec 21, 2008
    I DID I FOLLOW THE SAME EXACT WAY I'M JUST WONDERING DID I CROSS TWO WIRES CAUSE ONE WAS DISCOLORED THAT CAN PASS FOR WHITE OR DO I NEED TO RECALIBRATE THE T-STAT
    PLEASE HELP
  • poppydr May 25, 2009
    Honeywell T-stat costs how much
  • 446 Answers
It is always advisable to shut down the main swith to avoid further issues in replacing thermostat, if you follow the right color coding this should be no prob, unless otherwise it cannot detect the right temp then it will not stop until it reaches and senses the right temp.
Posted on Dec 21, 2008
Put in new Honeywell t-stat. Put new sequencers in. Heat runs for five min shuts off for 2 -5 min then back on continuously. Inside temp stays the same as set point???
What is the model number of the new thermostat? What could be happening is that the cycle rate needs to be changed or if it has a heat anticipator it may need to be adjusted.
Jan 30, 2017 | Honeywell Heating & Cooling
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
I am trying to replace this thermostat with a digital, neither of the 2 wires is labeled, what are the 2 wires?
One would be 24 coming from furnace the other sends 24 volts back when Stat tells it to. These wires should connect to R and W on stat or If This is heat only stat the two terminals on stat
Jan 20, 2011 | Honeywell Consumer Products Model...
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
198 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
