Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanning Problem HP 6110 won't scan. Message says Scanning Error. Cannot connect to PC. Copier, printer and fax work ok. Tried going to START ~ HP ~ Download Updates, but that option is not available.
  • cmk4 Feb 28, 2009
    I can print but no scan as I get an error can't connect to pc. I did not load any software.
    Problem Solver:
  • 13 Answers
  • 446 Answers
Either your connection via USB is not connected or the printer scanner itself is not recognized by your pc, ensure first that you were able to print, if not see in your own printer icon if it does recognize the presence of your desired printer. either of the two you need to have the connection first in order to scan, and an application software to use
Posted on Dec 21, 2008
"Cannot connect to PC" is the message that I am
hello
have you tried uninstalling all the HP software for the all in one - and then re installing the software and drivers ?
if not, try it ..
if it still does not scan , go to this site and read .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02661093&lc=en&dlc=en&cc=us&lang=en&product=79477
i hope this helps .. if it doesnt , please advise what operating system you are using and if you have current updates for the OS. if not please update Windows to current level available from MS.
ps: i hope you purcahsed a UPS to avoid power downtime from local electricity company.
i hope this hleps
thanks for using FIXYA
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 - Scanning Error. Cannot connect to PC
Uninstall and Reinstall the software
1 On the Windows taskbar, click Start, choose Programs or All Programs
(XP), choose Hewlett-Packard, choose hp officejet 6100 series, then
choose HP Uninstaller.
2 Follow the directions on the screen.
3 If you are asked whether you would like to remove shared files, click No.
4 After the program finishes removing the software, disconnect your
HP OfficeJet, and restart your computer.
5.Do not reconnect the Officejet now
6 To reinstall the software, insert the HP OfficeJet 6100 Series CD-ROM into
your computer’s CD-ROM drive, and follow the instructions that appear.
7.After the software is installed reconnect the usb cable and allow the
computer to detect and install the software
If this doesnt work then get back to me
Nov 27, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Want to scan a document to my PC....However, when I start the scan, there is no activity and after several minutes I get "Scanning Error" message....
You just need to open the "Paint" application under your Accessories menu. Then go to the File menu and select scan. The image will scan to paint and you can save it from there.
Jun 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Keep getting scanning error message
How do you have the HP6110 connected to your system? This problem can sometimes be caused by using to long a cable between the computer and the multifunction printer. I would use a short cable (6 foot or less) to make sure that it's not a communications problem. This ususally manifests itself with an error message while scanning although the printing function work ok.
Apr 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger alfredo_torreliza2000@yahoo.com plz send your answer to this yahoo messenger
Jul 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP officejet 6110 all in one scanning
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
282 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
