Question about EliteGroup P4VXASD2 Motherboard
POWER LED hook up
I have a p4vxasd2+ V 5.0 MotherBoard. It has a (Power SW) which i found the proper slot. The (POWER LED) hook up from my tower has three pronx. wiring diagram does not help. Does anyone know how to make this hook up (POWER LED) What does it mean. There is a fan system which has three pronx.
Thanks for your help
  • 1 more comment
  • l_molinaro Dec 21, 2008
    It has two wires three pronx. The wires are to the outside pronx left and right. The middle pronx does not have a wire.
  • Lee2fixit May 11, 2010
    Does the Power LED plug have three wires actually connected, or is one position empty? If only two wires, do they align with the pins on the motherboard's Power LED connector?
    Does the Power LED plug actually have 3 wires on it, or only 2? If only 2, are they next to each other, or is there an empty one in between?
2 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: P4VXASD2+
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=181&DetailName=Manual&DetailDesc=P4VXASD2%20%20(V3.3)&CategoryID=1&MenuID=82&LanID=0
There you go M8!
just select the country you want to download the manual fror your MoBo;)
Good luck to you!
If you find my answer helpfull, plz dont forget to vote!
Posted on Dec 20, 2008
I just bought a new power supply for my new mid tower I hooked everything up the way it suppose to be the motherboard led , and he hard drive led ccmes on No screen
Disconnect all other connections on motherboard except the supply connection on motherboard and re fix RAM properly
Oct 31, 2016 | Computers & Internet
How do I re-conect the power on and off switch to the motherboard?
They should be labeled. The Power switch plug should say pwr. The Hard Drive Led should say hdd, etc. Look on the motherboard for the inscribed label.
May 23, 2012 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Dont know where to hook up the power and leads on the p4m80 -m4 to get power
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
Jun 29, 2009 | Biostar P4M80-M4 Motherboard
No power and I need wiring diagram for jumpers
Hi !
Via VT8237R is a chip that is on your motherboard. It does not determine your motherboard, and this chip is used in many different motherboards and producers of motherboards.
Try to locate the model and producer of your motherboard.
Usually it is written between PCI SLOTS or close to the RAM slots or close to the VGA Slot.
Finally, there is also possible to find a diagram written on the motherboard or close to the pins, with description of +/- pins.
Regards.
Apr 28, 2009 | VIA ASUS A8V-E Deluxe K8T890 chipset...
New tower
the symbol is there writen there on the board or abrivation you can follow it.. like( pwr sw/ Hddled/ spkr..
Apr 17, 2009 | MSI K8N Neo3-F Motherboard
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Sep 13, 2008 | MSI K8N Neo4-F Motherboard
How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Aug 20, 2008 | HP Computers & Internet
EliteGroup P4VXASD2 Motherboard Logo
147 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
