Question about HP Photosmart A617 All-In-One Printer
Cartilge Fails What to do when the screen says Cartlige failed
  • 446 Answers
It means that the cartridges have some prob, either its defective or need to clean, cartridges is the ink container, which holds the whole color, separately into two, one is black the other one is MCY or color
Posted on Dec 21, 2008
Konica minolta scan to smb fails code 9144
Scan to SMB fails.Code 9144.
This code is not trouble or error code.This is the job number.So when scanning fails and you get this screen with the code then select the recent failed job and click on "Details" you will get the details about the failure of Scanning.Then note down the reason/detail and ask again.
Thanks
Jul 10, 2014 | Konica Minolta bizhub C250 All-In-One...
Android tablet fails to boot. "Green Man" screen comes on, start stalls on next screen
you will need to try power +volume +up +down
Or power +home +volume down then
Factory reset
Dec 10, 2013 | Computers & Internet
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
Auto head align Fails screen says "change H
You need to print an alignment page. After you print it, you will be able to align the page using the up and down arrows.
Jan 27, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
Fails to save
my game airport tycoon 3 fails to save program if it save and i go back to it when i press to laod saved games , the screen goes blank and sends me back to windows
Jan 16, 2009 | Global Star Software Airport Tycoon 3 for...
Does not printer
It sounds like an ENCODER STRIP, not worth fixing.
Dec 02, 2008 | Lexmark X2350 All-In-One InkJet Printer
Laptop gets colored lines on screen when opeend then they go away
Possibly vga chipset is failing.
Noting to do. If it fails it fails.
Mar 26, 2008 | Compaq Presario M2000 Notebook
Changing ink cartridge in dell photo 966
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Mar 25, 2008 | Dell 966 All-In-One InkJet Printer
Screen saver problems boot problems
ok the disk check can be turned off in the bios setup
when you turn it it it says something to the effect like
"Press Del to enter setup"
what ever key it ask you to press press it..
in the setup change the first bioot device to HD0 or hard drive
Change the Floppy seek to off..
as per the screen saver,,
Try changing the screen saver to another one
If that fails turn the screen saver off
If that fails try a system restore to a date that this problem was not occuring..
IF THAT AS WELL FAILS THEN IT COULD BE HARDWARE RELATED
eighter memory or processor..
Jan 15, 2008 | Computers & Internet
HP Photosmart A617 All-In-One Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
