Question about Dryers
Gas dryer dont dry clothes,I changed ignator,but no light comes o
Kenmore gas dryer mod 110.74962300 runs but it does not heat.
  • 446 Answers
The element isnt burning thats why, you need a tech to inspect the element
Posted on Dec 21, 2008
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
Everything works but the clothes dont dry i changed the coils but that didnt do anything. i notice the ignighter isnt lighting up could it be that.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 10, 2011 | Kenmore Dryers
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My Kenmore dryer does not dry clothes completely and
This is dangrous you should call a repair man.
Aug 29, 2009 | Dryers
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
MY KENMORE DRYER WON'T DRY MY CLOTHES
you need to clean out the dryer vent hole and the wall vent hole,that is your problem it's not letting the wet hot air out-mike
Mar 31, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
