Question about Motorola Mobility RAZR V3
Water damage from my skin
Hi My Razr is 4 months old. I take it with me running,apparently the moisture from my skin apparently got inside, and now its not working. With a new battery the pad lights up, but nothing on the display screen. Unable to recieve or send calls. Help
    Novelist:
    Scholar:
  • 111 Answers
You need to open the phone housing and try to dry up or clean the board for any wet situation or moisture and check for any bad connection specially the connector from LCD display into the main circuit board. This connection is frequently loose in Motorola phone due to the flipping function is not reliable. I am surprise that since a flip phone which is mean it will open and close almost every minute for million time per month or year htne how come they made the connection so loudsy. I have fixed these problems for my relatives and friends and always see this common failure in Motorola Flip phone. Everytime you are no longer see the display but still heard sound and ring which is mean that either your cable is loosen or bad then you have to replace it. Please see below link for hoe to replace the LCD: http://uselessinfo.pwp.blueyonder.co.uk/dismantlev3.htm I have an instruction of how to fix a water damaged phone but I have not been tried it before so you must read the instruction of water damaged guide carefully and make decision whether you want to do it. Please email me at joe_dao2003@yahoo.com so I can email you the link. I am at work so I cannot reach to my laptop hard drive to get the info. Try the link above to see how ot open the phone housing first then will try others later. Good Luck
Posted on Apr 07, 2007
Itching while having a bath
the water maybe to hot for your skin, especially if you have dry skin. You can try cooling the water a little and adding baking soda to the water it has a soothing effect on the skin or you can get the oatmeal brand of bath additives and it will sooth and add moisture to your skin. Then I would start applying a moisture cream after the bath. do a small area on inside of arm first to make sure there are no allergies involved. If this keeps up might be worth mentioning to your doctor.
Oct 14, 2017 | Health & Beauty
Tip
Love Your Skin
By following these few, easy steps you will be able to keep your skin healthy and beautiful for many years to come.
1. Make sure to protect your skin from the sun. Sun exposure ages and wrinkles the skin and increases the risk of skin cancer.
Use sunscreen. Apply 15 minutes before you leave the house.
2. Smoking, too, ages and wrinkles the skin by narrowing the blood vessels, therefore decreasing blood flow, which deplates the skin of oxygen and nutrients that are essential to skin health. So don't smoke!
3. Be gentle with your skin. Everyday cleansing and shaving can damage it. Therefore you should:
- Limit bath time. Long baths and showers remove oils from the skin. Also it's better to use warm rather than hot water.
- Avoid strong soaps. Better to use a mild cleanser.
- Shave carefully. Lubricate your skin before shaving, with shaving cream, lotion or gel. Use clean, sharp razors. And especially, shave in the direction your hair grows, not against it.
- Moisturize your skin. Use moisturizers when the skin is dry, preferably containing SPF.
4. Eat healthily. Lots of fruits and vegetables, whole grains and lean proteins help you feel and look your best.
5. Live a clean and healthy routine. Change the bed sheets and wash your towel often, to avoid rolling in and brushing with germs and bacteria. Set up a routine to cleanse your face before going to bed.
on Oct 14, 2013 | Health & Beauty
Tip
Treat your skin gently
Limit bath time. Hot water and long showers or baths remove oils from your skin. Limit your bath or shower time, and use warm - rather than hot water.Avoid strong soaps. Strong soaps can strip oil from your skin. Instead, choose mild cleansers. Pat dry. After washing or bathing, gently pat or blot your skin dry with a towel so that some moisture remains on your skin. Moisturize dry skin. Find a moisturizer that fits your skin type and makes your skin look and feel soft.<br /><br />
on Nov 23, 2010 | Health & Beauty
2006 Pontiac g6 headlight socket was burnt replaced it and it worked for a moment then went out again. What else could be wrong?
Do You mean the bulb or the plug? Is the lense assembley seal broke and water or moisture inside. One drop of water will blow the bulb, also do not handle the new bulb with Your fingers oil from Your skin will also be damage the bulb.
Jun 04, 2012 | 2006 Pontiac G6
Our Goodman air conditioner (4 yrs old) is not removing humidity/moisture from inside our home. Last summer the drain from the ac drained moisture, this year it does not and we have a lot (35%) house...
35% humidity is very low. So low in fact that you should be waking up in the middle of the night for a drink of water and your wood furniture will dry out and crack. No idea how your testing the humidity level but your home should run around 50% relative humidity, that is most comfortable to human skin and is what we shoot for in a properly sized a/c system.
If it truly is too wet inside and you system is not pulling the moisture it should, you may have a low refrigerant level in your system or low air flow over the coil. How is the temperature and run time on the A/C? Is it running an unusually long time? Does it not keep up with a hot day? All of those symptoms could mean either low refrigerant or low airflow at the inside coil. Changed your filter lately?
Jun 16, 2011 | Goodman Heating & Cooling
Tip
How to apply moisturizing
Moisturizers are the basic and the most important skin make up. Moisturizer is the most important substance required for the skin care. It does not only act as a cosmetic to create your beauty but it also stands as a protection to your skin. Moisturizers can be used when you walk out for a party or even as an Office Makeup. It provides moisture to the skin and no matter what is the type of your skin, you will need moisturizer to maintain its texture. Moisturizers are prepared from some formulations containing oil and water.<br /><br />Method to apply moisturizer<br /><br />Moisturizer should be applied with proper method to optimize its benefit. These are very simple tips but if you follow these, you will see the difference yourself.<br /><br />&bull;First of all wash your face and hands properly.<br />&bull;Take moisturizer in your palms and spread it. Now apply it over the face and neck.<br />&bull;Blend it thoroughly making upwards-circular motions.<br />&bull;People with dry skin should apply it more than once in a day and people with oily skin should apply only once a day.<br />&bull;Best time to apply the moisturizer is just after washing of skin, when it is damp. This is because when you apply moisturizer to damp skin, it locks the water in upper layers of the skin and prevents it from evaporation.<br />&bull;You should use moisturizer with SPF protection during the daytime. Also at the same time do not use the same moisturizer with SPF protection, at the nighttime as it may clog your pores for long term.<br />&bull;Avoid using moisturizer around the eye area because moisturizing lotion or cream is heavy for the skin around eyes, which is different from the rest of the face. Skin near eyes can become fluffy by retaining fluid. A separate eye cream should be used for that purpose.<br />&bull;Do not forget to apply the moisturizer on neck. Apply it in the upward strokes.<br />&bull;If you are going to apply foundation just after applying moisturizer, let the moisturizer dry for 5-10 minutes otherwise your foundation can become
on Nov 22, 2010 | Health & Beauty
Tip
4 Steps to Healthy Skin & a Younger LOOK!
Step 1: Eat Healthy
Eating healthy foods will improve the strength of your body and also the look of your skin. Eating things such as fried food and junk food is not good for your skin or your health. If you eat junk you will start to look like junk, especially if you don't take care of your body! Its definitely not a good look for your energy levels and you will eventually start to develop an old, wrinkly and lifeless look.
Facts & Tips: As we age, our metabolism slows down, so does the ability of our skin to regenerate. This make it easier for your tissues to restore and rejuvenate dry and dull skin by eating food that is filled with antioxidants, vitamins and minerals. These nutrients are important allies in making you look and feel younger.
Step 2: Take Supplements
It is usually hard to get all our daily requirement of vitamins and minerals from the food we eat. You should look for supplements, such as multivitamin tablets, that will help you reach your daily requirement of nutrients.
Facts & Tips: The supplement you need to take must have Beta Carotene (crucial for cell regeneration), vitamin C (aids in making skin more elastic and stronger), vitamin E (prevents scarring and slows the aging process), Zinc (helps in cell repair and growth), selenium (fights cell damage caused by UV rays) and essential fatty acids (important in tissue repair and restoration).
Step 3: Use Water
If you want to maintain supple and clear skin, you have to increase your water intake because water does not only help in moisturizing the skin, but it also assists in delaying the aging process.
Facts & Tips: Water is needed to eliminate the toxins and waste products of our body. Water is also vital in maintaining most of our body's functions and processes. If you are dehydrated, some of the functions of your organs will be affected. To prevent dehydration, you need to consume at least three pints of water everyday.
Step 4: Use Cream
After showering couldn't be a better time to cream up your face & skin. At this time, your skin pores will be open and take in anything applied onto it with ease.
*Follow these 4 steps and your skin will be on its way to a more newer & younger look!
Best Wishes!
~ Que
on Mar 03, 2010 | Health & Beauty
Phone completely locked up except the off key motorola razr
I think you need to take it to a Motorola service center to get it flashed. If its just 3 months old, should be taken care of for free under your phone's warranty.
However, please note that most of the cellphone companies DO NOT cover moisture damage or accidental damage under their warranty conditions. You might need to pay for the services, if your phone became faulty after getting wet, or being dropped, etc.
Hope this helps.
Sep 08, 2009 | Motorola Mobility RAZR V3
Moisture Indicator location question Samsung Gleam
Samsung's have 2 indicators now. One inside the battery compartment and one attached to the side of the battery.
The moisture indicator inside the battery compartment will turn pink if exposed to any moisture (including sweat, steam, etc.).
The moisture indicator attached to the battery will show up with pink/red + signs.
Hope this helps.
I am replacing mine right now so I can get a legitimate warranty problem handled.
Aug 07, 2008 | Verizon Communications Samsung Gleam Cell...
Motor Razy 3xx cellphone
yup...
its common prob for razr. if you can open your fon, check its flex coonector inside mayb it get loose thats why you dont have any display, if everything is fine... probably you have a defective flex connector or defective LCD...
Oct 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
