Question about Samsung MT1066SS Convection/Microwave Oven
Samsung SMH7175BC, Touch pad "blinks" then shouts down.
I remove from wall, and remove cover....works fine. As soon as I reinstall cover it seems to start "shorting out" when seconds. I again take cover off...it runs fine. Seems like a short or maybe a "weaken" sensor? I can not find anything lose or burnt. Once again, when the screws for the cover are loose, it runs fine. Help!
Shortie
    Novelist:
  • 152 Answers
Hello, that is a wierd try using a spacer or washer on the outside where the screws attach so the screw holds the cover but dosent go in that much this may solve it for you.
hope this helps
happy holidays
Posted on Dec 21, 2008
  • 1,800 Answers
Check if u can locate any burnt or blown Fuses.
also check the sensors.
Microwave oven front panel not working
The contacts behind the panel get dirty and greasy and can stop working. Remove the front panel use a q-tip and some rubbing alcohol to clean the contact pads on the back of the plastic front cover and the contact pads on the circuit board. Reassemble and it should work. WARNING! Microwaves have very high voltages in them more than 4000V that can easily kill. Make sure its unplugged from the power supply, let sit for a few hours to make sure the caps are discharged and DO NOT touch any of the high voltage lines or capacitors inside the unit, work only on the front panel.
Jan 25, 2015 | Samsung Microwave Ovens
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
    HELLO.
    The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
    The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
    1 Unplug the microwave from the wall outlet.
    2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
    3 Pull the grill off of the microwave.
    4 Remove the mounting screw from the top of the control panel.
    5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
    6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
    7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
    8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
    9 Plug the microwave back into the wall outlet.
    Thanks.
    Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    I self cleaned oven and at end f cycle the dor is still locked and the touch pad for the oven is not working. The microwave touch pad is working fine. I tried to rest breaker but the problem did not go...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Apr 30, 2011 | Microwave Ovens
    Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
    sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
    Jan 18, 2010 | Samsung Microwave Ovens
    Button panel does not work or it starts making 'pick-pick' noise
    The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
    May 18, 2009 | Sanyo EM-S9515W Microwave Oven
    Problem with the display
    I've checked, and cannot seem to find online service data on this model. Perhaps it's too new.
    But it sounds like you have one which has the glass LCD and keypad connected to the circuit board via a zebra strip type "rubber connector". This is what you referred to as the "black and white small foam like pad". It is called the rubber connector.
    It's similar to the model shown in the attached exploded view and it shows you what to clean.
    If cleaning doesn't work, you need to order the LCD glass and the rubber connector.
    You will probably have to call Tritronics with your model number to get these parts. They are toll-free at 866-779-5835.
    Oct 30, 2008 | Microwave Ovens
    Samsung MT1066SS Convection/Microwave Oven Logo
    Top Samsung Microwave Ovens Experts
    William Miller
    William Miller
    Oscar Netto
    Oscar Netto
    Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
