I removed a honeywell t-stat to replace it with another t-stat (digital) it was a deffected t-stat so i put the old one back on and now they're saying in the heat mode it never turns off. I'm wondering if i switched the common with the heat wire or is it something else i should look for? Thanks in advance for your help!!!!
  • 306 Answers
White to W
Red to R
Blue or yellow to Y
Green to G
Do you just have 4 wires?
Posted on Dec 21, 2008
Im trying to change my old mechanical Honeywell stat for this digital one.
what is the brand and model of your old and new thermostats ?
Apr 27, 2016 | Heating & Cooling
Can I replace my old Magic Stat CT3100 thermostat with a Honeywell CT3200 thermostat?
yes just make sure u relace all the wires in proper order, r-rc, w , y g,, remove one wire from old stat and install on new one or make drawing and write down all wireing colours and letters
Dec 21, 2015 | Honeywell Heating & Cooling
I have a 2001 Jaguar xj8 and I have to replace my thermostat. Do I just remove the three bolts and then take ouot the old and put in the new thermostat.
If the new thermostat fits the old base you should be good to go. Different stats make contact to their particular base in different ways. A different stat won't work with a base that was not make specifically for it. Just be sure you put the wiring to the correct terminals and even if its a wrong match, you won'y harm anything. If the 3 screws that secure the stat to the base all fit exactly right, its probably a right match. Be careful of the wiring, mount it and give it a try on all functions. Thanks for checking back. Roger
Dec 17, 2013 | Honeywell Programmable Thermostat Heater
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
We have a digital Honeywell Thermostat and it's not that old but we have the heat setting at 68 degrees and the inside temp is reading 71 and our fan doesn't seem to turn off.
Hi, Most all of the Honeywell t-stats have a temperature adjustment feature...also check the the cycle rate is the right one for your heating system... You will find all of this info in the manual for your t-stat...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Dec 08, 2010 | Honeywell Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
HONEYWELL T-STAT
it is always advisable to shut down the main swith to avoid further issues in replacing thermostat, if you follow the right color coding this should be no prob, unless otherwise it cannot detect the right temp then it will not stop until it reaches and senses the right temp.
Dec 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
